Off Topic--Problem With Drain Vent On Lavatory Sink
   / Off Topic--Problem With Drain Vent On Lavatory Sink #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Our home was built by a Vocational-Technical school class back in '74. I suspect that they forgot to vent the drain in one of the bathrooms as I get the sewer smell when draining the sink. The trap is in place so I'm guessing the only way it can vent is back up thru the sink drain. Anyone have suggestions as to how this might be remedied without tearing into the wall? (You may wonder why I haven't fixed this after 40 years:) Thank you in advance.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #2
make a longer P trap. further it goes down and then comes back up same distance. the more pressure gasses / air will need to come back through the sink. ((most likely will not fully work if "siphon / suction" gets strong enough to pull water out of the P trap)) have seen some pretty ugly P traps at local hardware stores. that i could hardly call a P trap.
most likely not to code. run 1/2" or so hose and tee into drain just after P trap. so the Tee is pointing up. run the 1/2" or so hose up through ceiling and tie it into the drain vent stack in attic.
you might try enlarging pipe at or just after P trap. to point it connects to a vent. so waste water drains in lower portion of pipe and air can flow in upper half of the pipe.
with above without proper venting. anything above more likely crud shot at best.
did someone leave a poo a tad to big and plug up vent for sink? *blames kids trying to flush stuff down toilet*
   / Off Topic--Problem With Drain Vent On Lavatory Sink #3
If you can see the venting in the attic you may fine the pipe has a belly in it which can fill with water from condensation or rain blocking the vent.
Thanks for the feedback. guys. I'll check the venting in the attic also. Any and all suggestions appreciated.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #5
If the house has a vent, which it sounds like it does, then I believe you may be able to add an air admittance valve. Note: I am not a plumber nor did I sleep at a Holiday Inn last night. Just watched lots of videos on You Tube. ;)
   / Off Topic--Problem With Drain Vent On Lavatory Sink #6
You can add a valve under the sink. I don't know the name of it but it was designed for use in islands with a sink. Don't want the vent pipe running to ceiling. But you tee it in on sewer side of trap and run it as high under the cabinet as possible.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #8
If it's been draining water and you have had no problems from 74 until now.. I doubt it's a vent problem..
Soap scum & hair will gather in the drain lines over the yrs and tend to smell just like sewage..
Take your trap apart and inspect the drain pipe
OP here. I hate to admit it but I've been putting up with it for longer than I can remember. I did clean the trap recently so I don't think that is the problem.
Thanks for the link to the air admittance valve. May have to give that a try.
   / Off Topic--Problem With Drain Vent On Lavatory Sink #10
If that's what the problem is. I would use/recommend studor vent brand AAV..I have use a number of these without any issues
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A50505)
2022 INTERNATIONAL...
2007 Dodge Nitro 4x4 SUV (A48082)
2007 Dodge Nitro...
2013 Honda Odyssey EX-L Van (A50860)
2013 Honda Odyssey...
1267 (A50490)
1267 (A50490)
2 Yard Commercial Dumpster (A49346)
2 Yard Commercial...
RoGator RG1100C (A50397)
RoGator RG1100C...
