6530 wont start
/ 6530 wont start #1
RMOMN
Member
Prior Lake, MN
Mahindra 6530,Farmall H,John Deere 620
The tractor started to just make a click when I went to start it so I would just keep trying then it would finally engage. This weekend it clicked once then nothing the battery has a full charge. shuttle in neutral, shifter in neutral, high low range lever in neutral nothing. I have not used the PTO yet, but I did confirm that was in neutral. I had to move the tractor so I jumped across the starter solenoid and it started right up. Any ideas as to what I need to check? I'm under warranty but my closest dealer wants $400.00 to pick it up and another $400.00 to deliver.
/ 6530 wont start #2
First step you need a volt meter. I like to work backwards. Start at the starter. Check see if you have voltage on small wire on starter solenoid with key in start. If not check the voltage at start relay. If you don't have 12v on two wires with key in start position check the safety switches. Check the ground terminal on relay also.( Poor Ground is the number one overlooked electrical problem) There is a switch on pto lever and also on the high/neutral/low lever. Check voltages going across switches with key in start position.
/ 6530 wont start
My operators manual says there is a safety switch on the PTO lever and the shift lever. I tried to find one on the high low lever and could not find any thing. The tractor is 270 miles away when I get back up in two weeks I will look at the shift lever and also try to locate the starter solenoid.
/ 6530 wont start #6
High low lever will also have a switch..I'll look on my 4530 and see if I cant point you in the right direction. They should be similar if not the same ..
/ 6530 wont start
Thanks, I could not find one
/ 6530 wont start #10
Rmoni,
Have the battery checked for amps. Had a one on my 5530 same click, etc. had battery checked out, showed full charge, then had the amp checked. That test failed no amperage to crank. New battery took care of that problem. This was 2014 July. No problem since. Batteries are not what they used to be since lead is not used anymore as I am told.
Idaho2
/ 6530 wont start
Rmoni,
Idaho2
When I jump the starter solenoid it cranks fast and starts right up.
/ 6530 wont start #12
check and clean both ends of each battery cable. If it starts when you jump the solenoid, then it's either a bad cable connection on the starter ( my bet) or a bad solenoid.
Also check the small wire that goes from the solenoid to the key switch for tightness.
/ 6530 wont start
I just got back from where my tractor is kept. It turned out to be a bad connection on the small wire coming from the key switch to the solenoid. Thanks for all the input.
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
Railroad Maintenance Machine (A61570)
Railroad...
2019 Ford F-350 (A55973)
2019 Ford F-350...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
