2006 John Deere Tractor 3203 won't start
   / 2006 John Deere Tractor 3203 won't start #1
JTobin
Renton
I purchased a 2006 John deere Tractor. I installed a new battery and the tractor started right up. I used it 3 times and now it won't start. The battery is charged tightened connections. When I turn the key it clicks and the electronics turn on the instruments panel. Took out the seat safety button. Press on the button and try to start and I hear a click. They engine does not do anything and makes no noise.
Suggestions of what to look at next. Thanks JT
   / 2006 John Deere Tractor 3203 won't start #2
I purchased a 2006 John deere Tractor. I installed a new battery and the tractor started right up. I used it 3 times and now it won't start. The battery is charged tightened connections. When I turn the key it clicks and the electronics turn on the instruments panel. Took out the seat safety button. Press on the button and try to start and I hear a click. They engine does not do anything and makes no noise. Suggestions of what to look at next. Thanks JT
Double check battery again, try to start with the charger on it. Sounds like you have a charging issue
   / 2006 John Deere Tractor 3203 won't start #3
JMER817 - responded faster than me.
Start with the simple things. What is the voltage of the battery, there could be something that has drained the battery? You might try and charge the battery, since it is a new battery I would think you would not have to charge it long to determine if that is the problem. Since you hear a clicking, I do NOT think it is a safety switch issue. When you do get it started test the voltage while the tractor is running to make sure the tractor is charging it.
Thank you for your suggestions. I did charge the battery again before I posted this. What else do I try?
   / 2006 John Deere Tractor 3203 won't start #5
What is the voltage of the battery with the tractor turned off?
Hi JMER817 Thank you for responding. I need to wait for my brother to check the voltage. Thanks again JT
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
Auger Drill Bit (A56857)
Auger Drill Bit...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
2006 JCB 520 Telehandler (A59213)
2006 JCB 520...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
