Mahindra eMax 22 Gear
/ Mahindra eMax 22 Gear #1
0xbeef
Rolesville, nc
none yet
I am considering buying a Mahindra eMax 22 Gear. Does anyone have any knowledge or experience with manual transmissions on these tractors? It seems that most folks go with the hydrostat. TIA.
/ Mahindra eMax 22 Gear #2
Welcome ! I have a gear 2415 series Mahindra and have had no problems . Just remember as with most all geared tractors to change gears while not moving.
/ Mahindra eMax 22 Gear #3
Is there any particular reason you are considering the gear over the hst?
If you're planning on using it as a mower, you might want to rethink.
/ Mahindra eMax 22 Gear #4
What do you hope to accomplish with the tractor? The Emax gear has been very successful for its price point and simplicity, I saw that someone said you can only shift gears when you are not moving, that is correct on some, on the Emax gear it is a synchronized transmission you can shift at any point.
The HST is nice do not get me wrong, its all in what you like and what you are comfortable with. if you are mowing the HST will be nice if you have a lot of small areas you are mowing, if it is wide open the gear will be nice so you can set it and go. loader work will be easier with the HST, but I also like being able to have throttle control on the foot throttle as I go in to a pile of debris I am trying to move.
A lot of things to think about.
The manual is cheaper and I don't mind shifting. I also believe that HSTs in general are less efficient and certainly harder to work on. Good to learn that it is synchronized. Thanks for the info. I will post if I take the plunge.
/ Mahindra eMax 22 Gear #6
Is it a shuttle like the Max26/28/ how many speeds?
Please see my Max28 shuttle review for what i said about gear.
/ Mahindra eMax 22 Gear #7
Less efficient fuel or power wise? Either way, you'll never notice any difference.
Harder to work on? They have way fewer moving parts, and very seldom fail. therefore much less need to have to work on them.
If they were inferior in any way, they wouldn't be in everything from lawn tractors to huge dozers and excavators.
A little more money, yes, but as a percentage of the whole sale, not much at all.
Well, I took the plunge and got the manual. It does not have the separate fwd/rev lever, but it shifts quite smoothly between 2nd and reverse, and I think I can make do with that. It will be coming next week. Can't wait for my new toy, err, tool to arrive
/ Mahindra eMax 22 Gear #9
May I ask what dealer in NC it was I bought mine from NC Safeway in burgras
/ Mahindra eMax 22 Gear #11
Safeway was great to work with to thanks
/ Mahindra eMax 22 Gear #12
The gear is the better choice for sure.. don't care what any claims say but you loose ground power with hydros.. try mowing with one in high 1st up a hill and try mowing with the HST in high range up a hill... youll see the difference
/ Mahindra eMax 22 Gear #13
My brand new eMax22 gear kept slipping into neutral when shifting to 1 or 3rd. The external linkage slides into different forks for 2nd and reverse and 1st and 3rd. So it can effectively be in 2 gears at one time. It's possible to take a big long screwdriver and realign the fork to the neutral position. The dealer seems to have fixed it with newer designed shift linkage that is less impeded by the fender and aligns better with the alignment plate that restricts linkage motion. The design seems problematic to me. If your thinking about buying one of these take a look at the forks when shifting from reverse to 1st.
/ Mahindra eMax 22 Gear #14
Its just the nature of the small handle gear shifts... your trying to go across the section from point A to point B when you need to over exaggerate the shift... so down to the middle then over then down into the gear... and always drag the side of the slots...
I have not had a lick of trouble shifting. Most of the time I am going 2nd <-> Reverse, but I have not noticed any problem with 1st or 3rd. I am very happy with the manual trans.
/ Mahindra eMax 22 Gear #16
I have the eMax22 HST it meets my needs. I think you need to think about what you plan to do with it, me I don't want to shift.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
1988 AZTE 45ft. 40 Ton T/A Flatbed Trailer (A59230)
1988 AZTE 45ft. 40...
