5 Pin/wire outlet identification
/ 5 Pin/wire outlet identification #1
mrtwister
St. Charles, Ontario, Canada
Kioti DS 4510HS
Greetings to all...There is a round female 12 volt outlet at the lower right-rear side of the tractor, situated under the fender area. Although it appears there is room for 6 connectors, there are actually 5 wires entering to 5 internal connectors. I've done an extensive search on the TBN forums and Google and can't seem to find any detailed information on this connector. Could this be a working light connector or a trailer connector? I would like to ID it so I can find the male counterpart to make use of it. Picture is included below. Any help is much appreciated...thank you.
/ 5 Pin/wire outlet identification #2
Try this link for a manual that should give you what you are looking for.
Directory Listing of /info-kioti/Werkstättenhandbücher/
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
18.4-42 Tires (A65640)
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
1062 (A63291)
1062 (A63291)
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
