Trailer brake voltage
/ Trailer brake voltage #1
Barnbuilder
Gold Member
Waxhaw, NC
Bobcat A300, Kubota F3680, JCB 212S sold
I have a 99 and a 15 F350. I have an enclosed gooseneck that I just put new brakes on. And I have a new 10 ton gooseneck. Neither of these trailers seem to stop well with either truck. I was checking voltage and at the junction box on the trailers I was getting 9 volts and at the axles 8 volts. Is there that much voltage drop? I can't get the brakes on either to lock up. The 99 truck has a P3 and the 15 has the factory controller.
/ Trailer brake voltage #2
My brake controller varies the voltage to the trailer brakes. The voltage applied to the trailer (0 to 12+) is controlled by the controller as you are stopping.
The manual override lever should apply full battery voltage to the trailer brakes. If you are applying the manual override lever and only getting 8-9 V there may be a controller problem. If the controllers are set up properly you may have a wiring problem.
Here's a link on the P3 controller. Owners manual should describe setting the factory unit.
p3 trailer brake controller adjustment - Bing Videos
/ Trailer brake voltage #3
We had to run heavier gauge wire from the controller on our 03. The difference was night and day. I'm assuming you're using the Ford harness.
/ Trailer brake voltage #4
How are the grounds?
Chris
Yes I was using the manual control lever.
Grounds are good the big trailer is brand new. Both controllers are set at max.
/ Trailer brake voltage #7
If you are getting 8-9 V at the trailer end, what V do you have right at the controller. If it's full voltage you may have to run a heavier wire back to the trailer plug like tcartwri mentioned. Also, double check your ground as Chris mentioned or try adding another ground with a temporary jumper from truck to trailer and recheck voltage.
Your 2015 should still be covered under warranty. If you can't figure it out take it back to the dealer and ask them to diagnose / fix the low voltage problem.
/ Trailer brake voltage #8
Check the voltage at the plug on the back of the trucks and compare. This will give you a starting point.
Chris
With the trailer unplugged I checked voltage at the socket and it was 12.5.
Yes I took it back to the dealer with a load on it. They tested the truck and said it was good. Turn the gain down to 3 and pulled it around the gravel parking lot and said it was stopping good. Well that's great but running 60 and hit the brakes it's not. I don't know if I'm expecting too much but I would think a 10 ton running gear would lock up when empty and controller at max gain. I did adjust the brakes and it helped. Maybe the brakes need time to get worn in.
I know on the enclosed trailer I just replaced the brakes and pulled them apart again and maybe half the shoe is in contact with the drum.
Get tired of having to fix things even when new.
/ Trailer brake voltage #10
Measuring the voltage will tell you very little. To calculate the actual voltage drop at the brakes, you need to know four things. Voltage, current, distance, and resistance of the wire. We know that there are already considerable losses in the factory harness if you're only reading 12.5 at the connector.
Typical electric brakes pull about 15A at full load for four brake drums.
Plugging those known numbers into a voltage drop calculator will show you very quickly why having the right size wire will make a huge difference in your braking performance on a heavy trailer.
In our case we went from a gain setting of 9 or 10, to 3 or 4 when loaded. The factory Ford harness simply was completely undersized for the job.
/ Trailer brake voltage #11
I'd check with Tekonsha. An olde-school controller (like I have) is easy to force to maximum output to test with - not sure if the P3 will do that at low speed in auto mode, even at Max gain.
Sometimes you have to outsmart the "smarts" in the box to get it to do what you want.
Anybody else running a P3 ?
Rgds, D.
/ Trailer brake voltage #12
See what the voltage is on the truck side of the trailer connector doing the above test. Like tcartwri, you may have to upgrade the truck wiring, if the voltage is already low coming into the connector.
I'd also run (just for a stationary test) a good heavy ground from the truck (jumper cables from the battery) and use that as my ground reference when measuring at the trailer.
Hear ya though..... we'd all like to think the point of buying new is that you aren't going to have to fool with it, at least for a long while.....
Rgds, D.
/ Trailer brake voltage #13
My wife bought a new RAM 1500 this summer and is having nearly identical problems with the factory controller. No matter how the controller is set, there is no way to get any more than a barely-detectable drag from the trailer when the manual controller lever is activated all the way. Took it back to the dealer, who said it was functioning fine. I haven't checked any voltages yet, but hate to think the truck brakes are doing nearly all the work...especially when this is a brand new vehicle. With our old GMC (with after-market controller), it was a delicate business to adjust it so it DIDN'T lock up the trailer brakes...but now, with this truck, that is impossible.
/ Trailer brake voltage #14
Check the amperage draw. Each magnet should draw around 2.5 - 3 amps when brakes are fully applied. You have to have large enough wire to handle the amperage. Many trailer manufacturers save money there. Grounding is also a place where many take a shortcut. The grounds should run through the plug on the tow vehicle and to the negative side of the battery if you want flawless braking. Grounding to the frame is a crap shoot. Dexter axle has some good troubleshooting info.
Dexter Axle - Trailer Axles and Running Gear Components - Resource Library
/ Trailer brake voltage #15
With the trailer unplugged I checked voltage at the socket and it was 12.5. Yes I took it back to the dealer with a load on it. They tested the truck and said it was good. Turn the gain down to 3 and pulled it around the gravel parking lot and said it was stopping good. Well that's great but running 60 and hit the brakes it's not. I don't know if I'm expecting too much but I would think a 10 ton running gear would lock up when empty and controller at max gain. I did adjust the brakes and it helped. Maybe the brakes need time to get worn in. I know on the enclosed trailer I just replaced the brakes and pulled them apart again and maybe half the shoe is in contact with the drum. Get tired of having to fix things even when new.
For the very reasons you described I have converted 2 of my trailers to disc brakes. No comparison!
Chris
To check amperage, do I need to cut a wire and put the meter in the path? Haven't done anything like that since college and that has been a few. I think I need to send the P3 back to Tekonsha. I can put my foot on the brake and the voltage will go up to 3 then back to 0 and start climbing again. Can make for a little pucker factor.
Day I picked the trailer up and got it home.
/ Trailer brake voltage #17
Current will have to be measured in series. I use something like bullet connectors when I have to break into a wire to test like that.
Before cutting into new wiring, I'd try briefly applying 12v directly to that brake control line on the (disconnected) trailer connector, and do a drag test on the trailer. Either use a separate battery, or if GNecks have breakaway switches (?), just pull that.
If you apply 12v to the brake line, and still can't drag the wheels, I'd say it's a trailer issue. On the truck side, I'd focus on getting 12v delivered out of the truck connector (like tcartwri described) before I'd spend time current testing each brake coil - it's a cart/horse issue....... you need full voltage available, before you can get rated current into a load.
For controllers, I'd use something like this for testing at this stage, or forcing full voltage to the control line:
Reese - Brakeman® Compact Brake Control
You may have a buddy with an old idled truck that has one you can borrow, or they shouldn't be big $ to buy new.
My :2cents: Rgds, D.
/ Trailer brake voltage #18
You can open the plug, remove the brake wire, and run power from the plug, through your meter, to the brake wire. Make sure your meter has adequate capacity. Four brakes should show a combined draw upwards of 12 amps with full brake applied.
/ Trailer brake voltage #19
Chris
Last year I converted my hydraulic surge brakes to electric brakes with the drum/shoe. Now I wish I had gone all the way and converted to disc brakes as well.
Messing with the "star wheel" is a PITA for me. The K-D tool #287 just doesn't fit the star wheel in both directions. If I can't hear/feel the clicks in both directions, I'd just be guessing for each adjustment.
/ Trailer brake voltage #20
Haven't tried them yet, but I'd expect that discs on trailer would perform well.
Noticed when I was looking for electric brakes for mine that Dexter makes an auto-adjusting model.
http://dexteraxle.com/i/u/6149609/f/product_flyers/Nev-R-Adjust.pdf
Rgds, D.
Hurricane THB750 Hydraulic Breaker Excavator Attachment (A61572)
Hurricane THB750...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
2020 John Deere 560R Premium Round Baler (A63111)
2020 John Deere...
UNUSED AGT - AC AIR COMPRESSOR (A64281)
UNUSED AGT - AC...
