Changed Fuel FIlter...not filled 100% with Fuel but running fine...OK?
/ Changed Fuel FIlter...not filled 100% with Fuel but running fine...OK? #1
sdk131
Calvert County
BX1870-1, 54" MMM, FEL
SO I just need a reality check here. I just did the 50 hr service that included changing the fuel filters. The front filter up by the engine will not fil completely with fuel.....but the tractor seems to be running fine. Doesn't seem like it should be since it sort of looks like it would be sucking air to me....but I ran it for about 30 minutes around the yard. Is there some trick to bleeding it? Or should I just not even worry about it as long as the tractor is running fine? Just doesn't seem right to me to have air in the filter.
/ Changed Fuel FIlter...not filled 100% with Fuel but running fine...OK? #2
It is normal. Running = All is well.
Eventually, the filter will fill with fuel. Check it again after 10 hours.
/ Changed Fuel FIlter...not filled 100% with Fuel but running fine...OK? #3
I agree -- if the thing runs well don't even bother studying the appearance of the fuel in the filter. I bet you never looked at it all that much BEFORE all this came up, right ? I see you are Calvert Co.... I am in St Mary's County...small world.
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
(160) PIECES OF 1"X6"X6' WHITE PINE TONGUE&GROOVE (A60432)
(160) PIECES OF...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
2020 GREAT DANE CCC-3314-01053 53FT DRY VAN TRAILER (A59905)
2020 GREAT DANE...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
