Ag tires on backward?
   / Ag tires on backward? #11
Some people do it on loader tractors for backing out of piles with a full bucket
Many municipalities do it on tractors that see a lot of payment/highway use (mowing tractors). The claim is that the reversed bars reduces tire wear.
I have heard that they wear less on pavement being on backwards.
Mine are frequently on backwards. It's too wide to trailer with the way the wheel centers are set. So if I don't need it wide or I'm trailering, my tread is backwards. It does affect traction.
It's just faster and easier with filled tires to lift one side, spin the wheel, tighten it and go.
Thanks guys, keep them coming!
437271d1439287764-ag-tires-backward-20140427_103025-jpg
My loaded rears are on "backwards" for the same reason as Loadstar, I've about 1/2 inch on either side of the tires. But I like the other excuses as well.
   / Ag tires on backward? #12
I had a 1960 Fordson-Dexta that I kept one rear wheel on backwards to help me get OUT of a mud pile. No 4WD, no FEL, just an old bare bones tractor. The extra grip on at least one rear tire when getting out of deep mud was sometimes all the extra grip that I needed.
For sure, I don't know if that setup was truly the difference in being stuck or simply driving out, but some Old Timers told me to mount one backwards, so I did, and it - in my mind, did help.
   / Ag tires on backward? #14
I see a lot of non-driven R1s on backwards like the steer axle of a 2wd combine or on grain buggies for example. I've been told by several different sources that they throw less mud in the air when on backwards.
   / Ag tires on backward? #15
How about when using a rear-mount snowblower. It should help when driving backwards, right?
   / Ag tires on backward? #16
It also helps with flotation when turned backwards on a non drive axle like the rear of a 2wd combine or on a grain buggy.
   / Ag tires on backward? #17
on a combine or grain cart they roll better in mud backwards, other reasons they don't tear yard up as much and sometimes the tire man goofed up
   / Ag tires on backward? #18
I have backwards ag tires on my zero turn to help with the steep hills in my yard. No more taking off down the hill with no chance of stopping.
Made a non-usable machine work like new. The wife even mows the lawn now :)
Fred
   / Ag tires on backward? #19
you can put the left tire on the right side and still accomplish this and have them both the correct way. but if your taking them back off i guess it doesnt matter anyway.
never mind i see you saiid its easier to just do one side at the time which i assumed is why you did that.
   / Ag tires on backward? #20
Local custom hay baler runs his tractors with the tires backwards to increase tire life when traveling from one place to another.
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
1990 KME (A55758)
1990 KME (A55758)
1991 GMC TOPKICK CHASSIS TRUCK (A54756)
1991 GMC TOPKICK...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
(INOP) 2015 FORD F-250XL SUPER DUTY SINGLE CAB TRU (A51406)
(INOP) 2015 FORD...
