I made an adaptor many years ago for my Ford 641 (1958 model) and just found out how poorly I welded it. Towing a trailer laden with lumber, one of "V" arm's weld broke. The remaining arm held the load but it distorted the main body of the adaptor. (see pic) I ground off the "V" arms and re-welded them using plug welds to a frame made of 3.5" angle iron welded together to form a box. It is a much heftier design than the original.
However, I had difficulty attaching the lift arms and anti-sway bars to the pins on the new hitch but after much manipulation I found that if I lifted the lift arms and anti-sway bars I could align their eyelets with the hitch pins managed to get it mounted. In other words, the eyelets and pins are not well aligned at all elevations of the lift arms but by raising (or lowering) the arms the sweet spot can be found. In spite of the tight fit, the new hitch allows me to pull the load shown in the pic.
I concluded that the most reasonable cause is that the short, stubby mounting pins on the tractor must have been bent when the old hitch weld broke. As short as these pins are, it is difficult to see how they would bend but I can't think of any other cause. The new pins are welded co-linear and the 3.5" box tube is straight. The shop manual does not address the pin removal/replacement. Can anyone advise me on this?
