Kioti DK40SE Front End Problems
   / Kioti DK40SE Front End Problems #1
stihl46
Lewis, ny
Kioti DK40se
Hello Everyone,
First post on here and I have a question. Earlier today I was using my tractor and noticed there were two missing bolts on my front steering unit. Not sure what the front drive/steering mechanism is called, but the bolts sat the top of the unit, right below the tire rim. I took the tire off to tighten the loose ones and replace the missing ones and the bolt snapped (all the others had sheared off) and the lower section of the unit dropped and was being held up by steering hydraulic cylinder.
I tried pulling it back up, into place but it won't budge. I took the castle nut off the steering link and can't get the threaded part pounded out.
I pulled the hub off to lighten it up but still am unable to get the whole unit off. Once off I will bring it to a shop to have broken bolts removed.
Any suggestions on how to get the steering link out? I sprayed it with penetrating oil and am leaving it sit for the night. Am I missing a step in removing this?
thanks for any help
   / Kioti DK40SE Front End Problems #2
How many hours on the machine? I would want the dealer to look at it because it sounds like a safety issue. Anyway, :welcome: to the forum.
   / Kioti DK40SE Front End Problems #3
First off, welcome to TBN!
Most often that type of steering component is a tapered part that fits though a flange and is threaded on the end. A common way to separate them is to put a heavy hammer on one side of the flange, and hit the other side with another heavy hammer....the tapered shaft will pop loose. In most cases penetrating fluid won't help.
If you can post a picture, that might help us give more specific advice.
   / Kioti DK40SE Front End Problems #4
Sounds like the OP maybe referring to the outer front axle steering knuckle and gear housing to main axle bolts??
   / Kioti DK40SE Front End Problems #5
Perhaps.Hopefully not. The sheared bolts are gonna be a pita.
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Bottle Storage Rack (A50860)
Bottle Storage...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A48082)
2017 Nitro Z 19ft...
