Kubota L4060HSTC vs JD 4044R
/ Kubota L4060HSTC vs JD 4044R #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
If last winter's extended cold and excessive snow wasn't enough to convince me to trade my L3240HST on a cabbed tractor, the deer flies this spring and summer have been particularly voracious! A cabbed tractor with heat and AC is in my future. I found a used L3560HSTC with 165 hours an LA805 FEL and a BH92 backhoe for $42k but already have a KX-121-3S mini-excavator so the backhoe isn't needed and the dealer won't sell the tractor separately. For the same price I can get a new JD 4044R with FEL, cab with the options I want, and one set of rear remotes. Or for $2,500 less I can get a brand new L4060HSTC with LA805 FEL and one set of rear remotes. I'd be keeping all my implements: 72" brush hog, 84" rear blade with hydraulic angle, 72" York rake, Farmi 291 logging winch.
I really like the comfort and ergonomics of the Deere, and the ability to back the tractor and control the lift arms while hooking up implements using the controls on the rear fender is a very cool feature. But the Kubota has a much tighter turning radius, feels more planted, has twice the clearance between the tires and fenders (room for ice chains in winter) and with the seat placed further back in the cab the visibility to the sides and rear is phenomenal! I like both dealers.
Tough decision!
/ Kubota L4060HSTC vs JD 4044R #2
Tough decision!
I like both... Tough decision. But the loader on that Deere is better than the LA805. I think you need the LA1055 to compare loaders appropriately. The Kubota trans is better and I think the Kubota cab is more roomy.
Throw a Massey 1742/1749 into the mix. Should be priced competitively and stacks up very nicely against the other two.
Good luck.
/ Kubota L4060HSTC vs JD 4044R #3
Can't really go wrong with either. Will you be the only operator? If not have the other person drive the tractor and get their opinion.
Well crud, Kubota just made the choice tougher by halting the $1500 instant rebate for those who don't finance. So now the price difference is a bit closer
/ Kubota L4060HSTC vs JD 4044R #5
I have an L4060 and like TSO mentioned, the Deere loader is quite a bit stronger. How much loader work will you be doing? The one thing I dislike on mine is the single pedal. All my previous tractors had the twin pedals and I prefer that set up.
I do like the hi-low option on each range of the transmission, more than I expected. Though it was a gimmick at first, but I find I use it all the time. It also has extendable 3 pt links which are a big help hooking up. The air blows so cold and the heat so warm I have can't have either on full blast.
Every tractor I've ever owned has been a Kubota HST, but I found the twin pedals of the JD surprisingly easy to use and think in time I would prefer them. The loader is for me basically a wheelbarrow as I have an excavator for heavy work. Also, like you, I found the hi-low switch unexpectedly useful. Side by side each tractor has good points that I would enjoy. The one thing that worries me about the JD is the small clearance between the tires and fender. Seems like if the chains picked up a chunk of ice or branch it could do some damage.
/ Kubota L4060HSTC vs JD 4044R #7
I just wanted to point out another viable option, there is a member on here who lives near me in Michigan, who is selling a low hour L 3540 cab with loader. I'm sure the pricing would be much more attractive than buying a new rig, plus you could avoid tier 4, and you would already be comfortable with most of the controls.
L3540 Cab Tractor
L3540 Cab Tractor
Tempting, but I absolutely need ag tires
/ Kubota L4060HSTC vs JD 4044R #9
Offer him $26,500 ... Then do a trade at a dealer for the Ag's. As a trade, I'd assume it would cost ya less than $1500 for a swap
/ Kubota L4060HSTC vs JD 4044R #10
Check with your dealer......mine gave me their own discount because I paid cash.
/ Kubota L4060HSTC vs JD 4044R #11
I'm in the market for a well priced used BH92 and I'm not that far from you... If you bought the used machine we might be able to pre-arrange for me to buy the hoe from you. Just a thought.
Luke - Having tried both the 3760 and the 4060 I really like the smoothness of the 4 cylinder 4060.
This morning I had a chance to test drive both tractors. Both are really nice machines and they are fairly evenly matched. The Deere looked like routine maintenance would be easier with all the filters within easy reach. I also liked the twin pedal design as the Kubota treadle pedal has grown to enormous proportions over the years. The remote hitch assist controls were easy to use and the cast 3PH parts were massively overbuilt. But there were no telescoping link arms so if the hitch assist ever failed I'd be worse off, the fuel filler was so high up on the left rear fender that in my golden years I'd need an elevated platform to reach it, and the cab (while well appointed) felt cramped compared to the Kubota.
Pluses for the Kubota were the spacious cab, fantastic visibility, quarter windows that could be opened when the AC and heater were not needed, easy to reach fuel filler, greater clearance between the tire and fender (important for those of us who use ice chains in winter) and the biggest of all is that HST-Plus which I've really come to appreciate on my L3240. The 3PH components are clearly not as beefy as the Deere's, but I've had four Kubotas and none of them had any failures back there. It also costs $2500 less than the Deere.
I guess I'm leaning toward another Kubota.
This afternoon I went over each tractor in detail, including extended test drives. And I have to admit I like the Deere 4044R cabbed more than the Kubota L4060HSTC. It was a bit bumpier ride because of the shorter wheelbase, but felt planted even when I put it in 4WD and climbed the 40 degree slope behind the dealership. The ergonomics were better, the controls easier to understand (less navigating thru the options), and the dealer really knew his product inside and out. When talking to the orange salesman I felt like I was dealing with one of the clueless workers at a big box store. I was concerned about losing the HS-Dual Speed function of the Kubota, but the Deere salesman pointed to a steep incline and tossed me the keys. The 4044R handled the slope quite easily, the extra HP over my current L3240HST making a huge difference. The spacious cab I found so attractive in the Kubota wasn't so attractive today; the extra space is between the seat and the steering wheel so unless you have a huge beer belly it's not of much use. In fact, I had to move the seat so far forward to comfortably reach the wheel that my visibility to the 3PH was impacted.
The starting prices were thousands apart, but by the end of the day each tractor was within $100 of the other. Green clearly wants this model to attract orange customers!
/ Kubota L4060HSTC vs JD 4044R #15
Get the one you like, sometimes a color change is a good thing. I'm moving to a larger property soon and have been thinking of switching to a 4066R, so I appreciate hearing your likes/dislikes on each.
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59908)
2005 KENWORTH T800...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
John Deere 50 (A60462)
2025 Pabreak 84in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak 84in...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
