Mowing How do I get the bush hog to operate on Yanmar 1500D?
   / How do I get the bush hog to operate on Yanmar 1500D? #1
justagirlonatractor
PM, GA
yanmar 1500D
Hi guys - Please help!!! I have a Yanmar 1500D with front-end loader and a bush hog. For some reason my bush hog has stopped working. The shaft isn't turning (not sure if shaft is the right terminology). It cranks, drives, loader and bush hog both raise and lower, but the shaft that operates the mower isn't turning. Anyone know which of the levers I need to adjust, and how do I adjust them to make this thing work? I've tried all of the combos I can think of and nothing seems to be working.
Many thanks!!!!
   / How do I get the bush hog to operate on Yanmar 1500D? #2
Welcome to the site... Make sure the pin that goes through the lever, and shaft is still intact ,and hasn't fallen out or broken.. I'm talking about the lever where you put the PTO in gear
   / How do I get the bush hog to operate on Yanmar 1500D? #3
Many thanks!!!!
You are putting the PTO in gear, are you not?
That's my question. I don't remember how to do that.
Thank you...I'll double check the pin in the morning. I don't think that's it. I think I'm just not remembering how to put it (the bush hog itself) in gear. And I apologize...I don't know the proper terminology. I do know how to put the tractor itself in gear, but not the bush hog part.
   / How do I get the bush hog to operate on Yanmar 1500D? #8
I don't have a 1500, But look for a lever other than the gear shift lever.. It maybe on the rt or left side... If it has more than 1 speed, Use #1 speed
   / How do I get the bush hog to operate on Yanmar 1500D? #9
Left of the seat down low, clutch in and select speed 1 and of you go.
   / How do I get the bush hog to operate on Yanmar 1500D? #10
Don't know that the 1500 is setup like the 2000. But push all the way down to shift into 1st. gear. Neutral will be one up then 2,3rd..
CATERPILLAR 325FL CR EXCAVATOR (A51242)
CATERPILLAR 325FL...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
