Mahindra 3510 will not shut off with key???
   / Mahindra 3510 will not shut off with key??? #1
Gunner628
donalsonville<ga
2006 Mahindra 3510
I have a 2006 3510 4x4, it has 276 hours on it...The tractor will not shut off when I turn the key to the off position, it acts like its is wanting to but never does. I have to "pop" the clutch to shut down. Where do I need to start?? Thanks
   / Mahindra 3510 will not shut off with key??? #2
:welcome:to the forum. I'd start at the fuel shut off solenoid if it has one.
   / Mahindra 3510 will not shut off with key??? #3
Now I'm not familiar with this particular model but to me it sounds like the fuel shut off solenoid wants to work but isn't. Going on that assumption from what you have written then I would say the electrics are all ok. So what I would do is find the solenoid and take it apart if you can. I'm thinking that it's sticky for some reason or other. There might also me some junk under the seat that is preventing it form seating all the way so that the fuel is shut off. The solenoid will be the part on the injection pump that clicks when you turn the key off and on. It should be a nice solid clicking sound. Hope this helps.
I should also add that it might be just as simple to replace the solenoid rather than trying to take it apart and putting it back together. It also could be just as simple as removing the solenoid, cleaning up the plunger and putting it back together.
Thanks guys, will check that out this weekend...
   / Mahindra 3510 will not shut off with key??? #5
Surely it's the same as my 4110, occasionally mine will not shut off completely with the solenoid alone, that's why they have a manual fuel kill down at the bottom of the dash that pulls the same linkage on the injector pump that the solenoid operates. Mine is a black plastic T handle that says "STOP" on it.
Yes sir, I forgot to mention about the little t-handle to shut if off. Thans
   / Mahindra 3510 will not shut off with key??? #7
yep i have had the same problem with our 2810. I pulled the rubber boot back and sprayed some penetrating oil onto the plunger and worked it back and forth by turn the key on and off. I havent had any more problems so far.
   / Mahindra 3510 will not shut off with key??? #8
If it fails to stop in the future..... idle the tractor at it's lowest idle... then block the air intake. That should stop it. :)
   / Mahindra 3510 will not shut off with key??? #9
My 4110 did this yesterday. It also had starting issues, thought it was a battery terminal, but doesn't appear to be the issue. My gauges also weren't working with the tractor running. I'm thinking it may be an ignition switch issue.
   / Mahindra 3510 will not shut off with key??? #10
i thought i had posted the same problem earlier on, but i don't see it here. we found the kill switch (i guess its the one you guys are talking about) solenoid was at fault. the battery kept going down. i found the solenoid was drawing voltage as long as it didn't disconnect. a little wd40 solved that.
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
John Deere 4020 Tractor (A50514)
John Deere 4020...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
