Sickle Bar Mower
/ Sickle Bar Mower #1
Nordite
Vancouver, WA
Kutbota BX2300
I'm looking for a Sickle Bar Mower in Oregon or Washington that will fit my Kubota BX2300. If you know of one for under $4000 let me know.
/ Sickle Bar Mower #4
Have you considered pull type sickle bar mowers?
/ Sickle Bar Mower
The only pull type I have seen were being pulled by horses.
/ Sickle Bar Mower #6
PTO pull type, from before everything had 3PT, are fairly common. Horse-pulled are wheel driven.
Horses don't like it when you try to hook up the PTO shaft.
Bruce
/ Sickle Bar Mower #8
pto vs non pto.... sickle mowers do not require a large amount of HP compared to a rotatory cutter or fail mower. but more of issue. does the sickle have an hydraulic cylinder for up/down.
that cutting bar can be a bear at times, trying to pull / push up and lock into travel mode. then dropping the cutting bar down into thicker weeds. and walking about in the weeds.
if buying used. double check the cutting bar itself. and the teeth on it and more so for any bending in the cutting portion of the sickle mower. it is not a cheap replacement piece of metal.
/ Sickle Bar Mower #9
Nordite,
I am fairly certain that New Holland still offers a pull type sickle bar mower. There are many pluses about the pull type. Finding a 3 point type that will fit your BX2300 may be a challenge.
/ Sickle Bar Mower #10
Nordite,
/ Sickle Bar Mower #11
/ Sickle Bar Mower #12
We have several used 6 ft mowers that are cat 1 and should fit ok. Ken Sweet
/ Sickle Bar Mower #13
Uh, I'm not sure of the Kabota 2300 hp/size, but the SFI outfit that Flusher suggested also sells Drum Mowers as well. I bought one of their smaller units a DM2555 and have used it two years now and really like it. It was right at $3000 brand new. The fellow at SFI answers his own phone and honestly tries to help a person. There's NO plugging and the blades (6) change out in about 15 minutes. I do have to keep the belts tight but other than that it's a Blow-n-Go show. I think Agri-supply May sell sickle bar mowers as well. Talk to the owners of Sickle bar mowers to see what kind of maintenance is required before you make up your mind. bjr
/ Sickle Bar Mower #14
I have a, 3-pt 7 foot sickle (Massey Ferguson model 31) on a B2710 (a little bigger than a BX23). No problem with the horsepower, but its a pretty heavy offset weight. Even set for the narrowest tractor its could come in about 12" more to fit the B-2710 properly. With the sickle on the downhill side it gets dicey if you have to lift it over something. Kinda needs a counterweight on the other side.
MOST of the time I like the way a sickle cuts.
/ Sickle Bar Mower #15
I had that same sicklebar mower. Used it with my 55 hp Mahindra 5525 tractor. It's pretty heavy for a 25-30 hp SCUT.
/ Sickle Bar Mower #16
At that price range you could get a new double action one from Enrossi and others. just google double acting sickle mowers. they make some small units that would fit your needs perfectly.
/ Sickle Bar Mower #17
They work fine if you keep them very sharp and have your machine properly adjusted. I cut 40 ac. with a 1960s ford 501 w 7 FT. bar I paid 500.00 for it on c/l . prob ably a little too much . I spent 2 days breaking everything loose and adjusting what I could . I bought over priced reprint manuals from ebay and I had to fabricate one piece that was missing. I also bought a belt for it. Then I cut hay. The machine I got had very little use . It is a nice tight machine. But it probably sat around for 30 yr. all of the adjusting bolts were rusted / froze up . It cuts very good .way better than my no. 9 john deere, my last yr.s mower buts that is another story If your buying used , make them put it on a tractor and put the power to it before you buy
/ Sickle Bar Mower #18
Also consider some of the drum mowers that are out there.They are also in your price range.
/ Sickle Bar Mower #19
I have similar experience...a MF 41 on a B1700...HP is not a problem but the cutter is heavy and a strain on the 3ph...(mainly on the right side arm)...I would not recommend one of the older heavy sickle bars for a BX...
I mostly use mine in the vertical position...usually once a year to trim the sides of the road...I bought a cylinder to control the bar but have not had time to fabricate the mounting brackets etc...
/ Sickle Bar Mower #20
This is worth repeating, over and over. Short of mowing over ditches or creek banks, I can’t think of one reason to choose a sickle bar mower over a drum mower. I really can’t even believe there’s enough market that they still make them new.
If you can’t tell, I grew up running a sickle bar mower. I despised that thing. Even when it worked perfectly, it was a PITA.
