loader will not drop
/ loader will not drop #1
blenderbender
Member
Western Pa.
Kubota B 3000
Howdy... I have a relatively new (167 hrs.) B 3000 with loader. I've been using it quite a bit lately cleaning up after a tree felling project. This morning as I was using it, all of a sudden the loader bucket will not go down. If I engage the auto down position it will go down, but straight down doesn't budge. Up, curl up & down, and auto down all function properly. I poked around for a crimped line or smashed hose yet see nothing. Any suggestions what might be the issue here or what to look for, or how to further assess?
thanks.... Gary
/ loader will not drop #2
check qd's. check valving/spool linkage.
post back.
Thanks souNdguy.... everything looks intact. I've realized it's an intermittent issue as after posting I went back to work with it and the bucket started functioning properly. But after a bit it hung up again..... then released at some point again. Sticking spool valve maybe?
/ loader will not drop #4
What is auto down?
Unplug and reset the QD's.
What I guess I should have said was 'float position' where it locks going down until you pull back on it. I'm not familiar with 'reset' qd's. Is that simply unplugging and plugging back in?
/ loader will not drop #6
Yes, unplug and replug.
/ loader will not drop #7
My old b7500 did that once. Turned out the 3pt lever was slightly engaged and not fully in the neutral position.
Thanks JJ.... I don't understand hydraulics all that well, but what exactly would unplugging and re-plugging qd's do? I did so, and it worked, but as stated earlier it is an intermittant problem and having left the tractor before and come back it often resolved itself until it happened again. I just don't get what anything as simple as that would do.
/ loader will not drop #9
One half of the QD might not release correctly, therefore causing no flow.
I would recommend either new QD's or rebuilding the old ones.
/ loader will not drop #10
Look at and lubricate the joystick linkages. This should be on a regular basis. Any chance any of the controls are being limited in there movement?
Thanks Egon.... I don't see anything that would be interfering. So far after QD unplug/replug it's still working properly.
/ loader will not drop #12
x2......Check the 3PH lever is not in the "Full Up" position....the symptoms are exactly like what you say
/ loader will not drop #14
When the loader does not drop, try putting the lever in float and see if it will drop.
If it drops, that means that the QD is good.
If the 3pt lever was causing backpressure, it could cause the loader to stall, and at that point, recheck the 3pt lever.
A 3000 psi hyd gauge will tell you if there is pressure in the flow path, and is a good indicator that something is not right. Should see very little pressure with all valves in neutral.
When using the loader or any cyl and d you see relief pressure on the gauge,and nothing is moving, that is indicative of a blocked QD.
2015 Ford F-150 Pickup Truck (A62613)
2015 Ford F-150...
SHORTWOOD 5 BOLSTER LOG TRAILER (A64276)
SHORTWOOD 5...
2014 Lincoln MKS Sedan (A61574)
2014 Lincoln MKS...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
