BX1500 LA181 Hydraulic Cylinder Leak
/ BX1500 LA181 Hydraulic Cylinder Leak #1
Robert_Parent
MN
Kubota BX1500
Hi,
Does anyone know if the seals on the LA181 FEL hydraulic arm cylinder can be rebuilt or must the cylinder be replaced? The rod seal is leaking a small amount and like most oil leaks quickly creates a huge mess.
Thanks,
Robert
/ BX1500 LA181 Hydraulic Cylinder Leak #2
Hi,
Thanks,
Robert
Should be repairable. I'd take it to a local hydraulic shop. They can generally rebuild hyd cylinders at reasonable cost vs cost of replacing.
Thanks, did not think about that option. It also sounds like Kubota may have a kit as well....
Robert
1991 International 4900 Box Truck (A55315)
1991 International...
2005 JOHN DEERE 160C LC EXCAVATOR (A59823)
2005 JOHN DEERE...
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
