How you protect your farm from theft???
   / How you protect your farm from theft??? #21
Caution: This Property Protected by Trained Attack Turtle....!!!
Turtlenado, Ah He77 No.....!!!!
[[[ slow morning :) ]]]
   / How you protect your farm from theft??? #22
I prefer:
No one knows! The Shadow do!
if I cant stop thief, I can find it if video catch him. IP cameras is good for me because I am strong in IT. But camera must be hidden, smallest possible. You can show only fake cameras visible. If thief destroy them he think that job is done. Wrong. IP hd cameras is costly, maybe I will make some cctv from web pc cameras.
   / How you protect your farm from theft??? #24
No need for IP cameras. Get a DVR. The DVR has a single IP and remote log-in software (no monthly charge) and you use regular, commercial-grade hi-def cameras. The only people I see using IP cameras, web cams, or game cams are amateur, do-it-yourselfers. I've been doing CCTV for 18 years.
dvr record every cam in full resolution? do you have some example for cheap 4 channel hd cctv?
   / How you protect your farm from theft??? #26
   / How you protect your farm from theft??? #27
I guess I must be an amateur, and a good friend of mine who works for SLED here in SC who also uses IP during drug surveillance is also a amateur. If you cant tell, I took offense to the amateur comment as I am by no means a amateur. People like the idea of being able to be away and be alerted to issues at home. They also like the fact that they have 24hour recordings of events that may have happened. I also do not post anything about my cameras on my property like. Less said the better they work. I also install for others that ask. So far none have had any issues even when away from their homes. I also use battery backups in case of power outages so they can still be viewed at anytime. So to be called an amateur is a little harsh. Thanks..
   / How you protect your farm from theft??? #28
Never worried about it. Its too big to carry! :)
   / How you protect your farm from theft??? #29
He is 170 lbs, he can rest his head on the edge of your car window. And if you do decide to shoot him you better be a good shot, because the other two dogs are going to be real pissed.
2020 Freightliner M2 106 2,000 Gallon Water Truck (A55788)
2020 Freightliner...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55218)
2015 Ford F550...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
