i1046 mulching poorly. what am I doing wrong?
   / i1046 mulching poorly. what am I doing wrong? #1
runrider
PA
None
Im no expert, but i think my cub is mulching poorly...after 4 or 5 days between cuts, my lawn is too thick and the clippings just pile up. Im no expert, but i think my cub is mulching poorly...after 4 or 5 days between cuts, my lawn is too thick and the clippings just pile up. Is there something I can adjust or replace on the mower? Am I doing something wrong? Should I just buy a bagger?
I'm using an i1046 zero turn tractor. Is there something I can adjust or replace on the mower? Am I doing something wrong? Should I just buy a bagger? Just look at the clumpy mess in the photo.
   / i1046 mulching poorly. what am I doing wrong? #2
some of these things you may already be doing... Full throttle. Only cut 1/3 height of the grass in a given pass. Cut only when grass dry (no moisture showing on fr tires). Slower ground speed (mulching speed is always slower than side discharge in heavy/damp grass). Blades/Deck sharp and clean (easy to clog if damp. Set of riser stands are very handy for quick underside chk). Properly leveled deck per manual.
   / i1046 mulching poorly. what am I doing wrong? #3
One of the things I've learned is recognizing the type of grass you have makes a big difference in mulching efforts. A Kentucky Bluegrass as an example is much more dense than a Fescue or a Ryegrass . . For the same height. Mulching vitally depends on speed of cutting blades and spacing of grass blades and lack of water. So mulching a less dense grass doesn't hold moisture as much or slow the cutting blades down as much. Moisture and density slow blades.
What I'd look for or do is:
1. Look under your deck for buildup on the deck. If you have it . . take the deck off and clean the buildup off. Soak the buildup if needed. You want to see yellow paint everywhere.
2. Just like a car or truck . . Washing and waxing keeps dust and dirt from collecting . . so after cleaning the bottom of your deck . . Spray it with a Teflon type product like No Mow spray or other brands (available at TSC, Fleet Farm, etc. etc.) . The key just like waxing is 2 light coats not 1 heavy coat and let it dry well. This should last for most of the full season depending how clean you got it to start with. Incidentally . . spray your mulching plug too and the area around the blade spindles. Also while deck is off is a great chance to grease the zerks under the deck. Every way to reduce resistance and keep blade speed up makes for better mulching.
3. If you have a dense grass . . then dry grass needs to be DRY grass to get a best result. And if your goal is a grass cut at 2.5 inches . . and your grass is 5 inches when you start . . either slow your forward speed or double cut . . because proper mulching takes power. If the grass is higher than 5 inches . . you'll need to double cut at different heights.
4. I had one lawn that had a lot of weeds in it. Weeds hold more moisture than grass.
5. I have an I1050 and it does a good job mulching . . however make your judgement after 24 hours . . because mulching requires the "mulch" to drop into the dirt. Normal discharge cutting wipes the grass away so it looks clean . . mulching depends on absorbing it away . . So it won't immediately look as clean but 24 or so hours later it should be much better.
Of course the above assumes your throttle is set to full . . Your blades are mulching blades . . and sharp . . and your engine is running smoothly and you are using "water free" gas . . either non ethanol or using a gas treatment and plugs and carb are clean.
Hope this helps.
Thanks fellas. I'll try keeping my deck clean... Something I have neglected up to now. How frequently should I sharpen my blades?
   / i1046 mulching poorly. what am I doing wrong? #5
Frequency of sharpening depends on
how much you have blades hitting obstructions like branches, rocks, sand, dirt, or mole hills ? You can feel the blades for sharpness . . .or look at the grass blades you've cut. Essentially . . If you are tearing the blades off . . . then you aren't cutting :)
   / i1046 mulching poorly. what am I doing wrong? #6
I'd make sure the front of the deck is lower then the rear by about a 1/4" and otherwise you are cutting quite a bit more then 1/3rd the height. I know I'm on a 3/4 day rotation for mowing and by the 5th day mine is also bunching.
What does cut vs torn grass look like?
   / i1046 mulching poorly. what am I doing wrong? #8
Cut grass is typically a straight topped grass blade wheread "torn" has a very irregular shape to the top of each grass blade and it "leaves a whitened edge". That whitening is the same kind of effect ad when you cut a piece of rope with s dull blade . . Its a bid raggef and shredded and a little stringy.
Well cut grass blafes typically look green right upnto the top edge because they heal quickly where torn blades dry out at the top edge.
2011 Toyota Corolla (A55758)
2011 Toyota...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A55788)
2016 AutoHauler...
Metal Peacock Statue (A55758)
Metal Peacock...
