Price Check 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal?
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #1
JDL130
Emmitsburg, MD
JD, Kubota
Decided to up my search to smaller used tractors for mowing. I am going tonight to look at a 2005 Kubota BX1500 with 54" MMM for $5k at a local dealer. Does this seem like a decent price for a unit with 520ish hours?
Kubota dealer nearby offered me $700 in trade for the JD L130 I just put the transaxle in, towards a BX1850 with 200 hours for @ $8k, but I'm leery because of the reverse jump issue in the BX1850s -- which I noticed on this one just test-driving it in the parking lot.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #2
If in good shape and well maintained it sounds reasonable. May see if there is some negotiating room with the dealer. Can't hurt.
Only other BX1500 I've seen lately has 900+ hours and another dealer wants $6995 for it, that's why I am curious where they range.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #4
That's probably a pretty good price (for you) for that BX1500. For that price, it clearly doesn't come with a FEL. If it did include a FEL, that would be a great price. The 520 hours wouldn't concern me unless the tractor looks like it was not treated well. See if they have any service records. And find out if they've serviced it since they took it in. Unless it has had a recent service, it should have a complete fluid and filter change (oil, hydro and front axle), fuel filters, air filter and coolant.
But if it's just for mowing, there are better mowers out there for $5,000, which get's you into the price range of gently used commercial ZTR mowers. I don't remember if there's a reason you need a small tractor for mowing instead of a ZTR, so if you do need a tractor you can ignore my last comment.
I have a large yard area but it's spread out into smaller sub-sections (front, rear, sides) with lots of interruptions in between. A ZTR is almost too much, because of all the obstacles, etc. a tractor is just easier to maneuver for me.
The other thought behind the tractor was that I could also pull a small bush-hog and save the hours on my bigger FEL-equipped tractor for doing the hilly pasture area behind and beside the house.
I got frustrated by the generally poor quality of the transaxles in most of the gas mowers up to about the $3-4k price range so I started thinking perhaps a good used SC tractor for not much more wouldn't be a half bad idea.
Local dealer who sold me all of my other equipment actually has a BX1500 too with @ 900 hours which they are willing to deal on and will even give me trade towards the JD 130 with the new transaxle I put in it that covers my parts cost and labor, so I will take a look at that one when they bring it in from their other location.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #6
Well, if that $5,000 BX1500 is in good shape, you couldn't lose much money on it. It you use it and don't like it, you should be able to sell it and get most or all of your money back. I don't recall ever seeing one for less than $5,000. Heck, even the John Deere X5** series garden tractors are that much or more.
It's just that the MMM is a pain in the arse to me. I bought a rear finish mower and I'm much happier with it.
That's what I'm thinking -- the X5** series are way less tractor than one of these, for more money.
Does the MMM give a decent cut?
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #8
My MMM gives a very nice cut. I just hate removing it and reinstalling it. It's much easier to unhook and reattach the 3 point mounted finish mower.
And for me it's easier to remove and sharpen the blades on the RFM. I just raise it up, put jack stands under it, and then get under it and remove the blades with an impact wrench.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #9
The Kubota BX1500 is a nice SC one of the smallest that offers a diesel engine, two range hydro tranny, 540 pto and 3ph. I think the price is fair if it is in good shape. You can do a lot with a small machine like this working on a lawn.
The x500 is a lawn tractor with nice features and a good transmission. With a much more powerful engine it would be better and or faster for mowing.
I suspect I would go for the BX1500 in this case since it can handle a wide variety of different tasks.
Well, they're picking up the Deere and dropping off the BX1500 today, so we'll see how it goes!
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #11
Good luck with it. I sold my JD rider and just use my BX MMM. Better and faster mowing with the BX.
I am looking forward to it. When we bought the Deere we had a fairly flat lot we were renting while we waited to close on the new house, and I didn't know anything about the K46 beyond that they failed if you didn't change the fluid. We ended up with 5 mountain acres that are just a bit too trying for the Deere. I figured it was only a matter of time before the new transaxle took a dump too.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #13
Congrats on the BX1500. Let us know how you like it. It should be a good tractor for you.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #14
Congratulations on the BX
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #15
I think the BX will be a very good machine for your uses, let us know how you like it. Congrats!
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #16
I'm kind of in the same boat that you were. I need something better than a lawn mower with a K46 in it. Would like something with a locking diff or 4wd. But the idea of spending $5k for a lawnmower is still hard to swallow. So far the only lawn tractor I have found in the $3k range is one made by Husky that has the k66 with a locking diff and a fabricated deck. I haven't looked for a used Kubota yet but figured I would once I was more serious (hoping to make it through this year). Let us know how it works out for you.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #17
How do you like it JDL?
Sorry for the delay, wanted to wait until I had a couple of mowings in before I replied.
So far, so great! I've got about 3 hours on it since I bought it. I need to change the engine oil and fuel filters, hydro oil looks good.
Everything works really well. The power steering is great -- I can maneuver pretty tightly around some of the trees and things in the yard. Also, the tractor will climb some of the slight grades that vexed the John Deere, so I end up weedwacking less.
The ROPS takes some getting used to -- a couple of trees that I used to just roll right under or duck to get under have gotten whacked.
I may eventually get turf tires for it as it has an industrial-type bar tire on it. Not a problem but maybe more aggressive than necessary for the yard. Cut is great although the 54" deck glosses over some areas where there is a contour so I've had to adjust my mowing to come at them from the side of the deck so it doesn't straddle small ravines, etc.
All in all, I like it a lot and would do it again. Waaaay more tractor than I could have gotten in a gas model for the same price.
Also I think it's quieter than the L130 was. LOL.
My wife was initially skeptical about the need for a second orange tractor but I showed her how to use it and she can mow pretty well with it too, although I generally end up doing most of the mowing. A few more things to know than the Deere for her but once she gets the hang of starting in neutral, engaging the PTO, etc., she's good.
Also should add, I ordered a copy of the owner's manual from the Kubota dealer, which was nice to have. Learned a few things about it that will be helpful.
Does anyone know how to take the deck off one of these? The owner's manual doesn't cover the deck, viewing it as an attachment. I haven't been looking too hard yet but I haven't found a PDF manual that will tell me how to take it off. I imagine it needs to come off to access the hydro filter when it's time to change that.
/ 2005 Kubota BX1500, 520+/- Hours, $5k -- Good deal? #20
Cool, glad to hear!
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
PALLET OF (47) 2"X2"X13" TUBING (A60430)
PALLET OF (47)...
UNUSED IRANCH 23" GRID SHAPED MINI EXCAVATOR BKT (A60432)
UNUSED IRANCH 23"...
