Your opinion on which is the right tool for the job
   / Your opinion on which is the right tool for the job #11
I think regardless of the tool used, incorporating humus into the soil is key to getting a better soil consistency & structure... you may need sand as well. Wood chips, compost, grass clippings, seaweed, cow manure, etc. will soften the structure and keep it from bricking up the same way on you. I think the ripper/middle buster idea is good for getting the depth workable, then a disk or tiller would work the organics into the mix. You can look at sweep, chisel and plow fronts to put on the middle buster.
It sounds like soil that would hardpan easily, so a disc might be the best option for getting established... a tiller will smear clay over time...
I have been dealing with softer and richer-looking clay here. It is challenging--I found wood chips and grass layers from years past down in 'the pan' and flipped it this year. I think it will good stuff, but it took me right to the initial clay layer I started attempting to work 10 years ago. Getting a deep enough bed for what you want to grow--and keeping it loose enough to infiltrate will be a challenge, and require substantial amendment. The issue with adding is that you increase your soil volume/depth over time and the bottom will get 'deeper', and harder to reach with tiller. If a lawn is what you're looking for though, you won't need to be preparing it annually--only once
This will be a building year for the future, so a legume crop over the amended soil will keep erosion down and work passages to your bottom clay, as well as add organics and nitrogen for next year.
That sounds about right Brown40. As long as I can break the soil and get some fertiliser into it I will be able to get the cowpea and millet to grow. In the future a bout half of the place will be lawn I hope and the rest garden beds and flower beds, so they will need a lot more work.
Finally got a couple of ripper teeth delivered.
I am going to weld 2 pieces of angle iron to the leading edge of the tool bar.
Drill the angle iron to allow me to bolt the ripper teeth between them so the force is against the tool bar rather than the welds
I have the metal cut to size and drilled.
This is how the teeth will bolt to the angle once it is welded in place
Next week weld it together.
Well 50:50 one ripper tooth held but the other snapped the retaining bolt.
So I will adjust the tooth mounting point and re test
Not so great.
The retaining bolts on both teeth sheared. Better them than something more expensive.
But I also see that the locating hole in one of the teeth has been expanded out of round slightly.
I will re drill the angle iron holding the teeth to the tool bar for 2 bolts, after that I can only guess that I will need thicker bolts, current ones are 12mm or just under 1/2 inch.
   / Your opinion on which is the right tool for the job #16
Not so great.
Look into spreading some pelletized gypsum too. An annual application of 30lb per acre x average annual rainfall in inches will make a big difference in a couple of years. Gypsum causes the clay particles to bind together into larger pieces so the soil takes on more the texture silt with better water infiltration.
Thank you , gypsum it will be
   / Your opinion on which is the right tool for the job #18
It looks like the center of the bolt is not very far above the bottom edge of the bar that forms the back of the pocket for the ripper. That will give the ripper too much leverage on the bolt. You want to spread those points of contact out as much as possible. If you weld in some pieces of flat bar to fully enclose the pocket front and back, especially the top front and bottom rear, so the bolt is only setting the height, you should have better luck. Most implements that use those rippers put them in a fully enclosed pocket.
Thanks Brad
Looks like it will have to be a redesign like you suggest.
I did make a 2 bolt attempt and that just sheared. So I will have to find a Pocket design to copy.image.jpg
One bolt sheared through, the other part way through.
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
Miles read : 112,969 (A50323)
Miles read ...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2001 GREAT DANE 53' CONTAINER TRAILER (A51243)
2001 GREAT DANE...
VEGETABLE TRAILER (A51244)
VEGETABLE TRAILER...
