Coyote Machine (this pic is for you).
   / Coyote Machine (this pic is for you). #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
These are my rear wheel weights on my DK40 se I promised to send ya.They are mounted on R1 ag tire/rims..Sorry it took so long,been busy.
   / Coyote Machine (this pic is for you). #2
I like the idea of wheel weights, my tractor is too light at the rear, and it's often too much trouble to go get a 3-pt weight. How much do those wheel weights weigh?
I'd like to see some pics of DIY weights attached like that. If I can find a 'sheet of 1+ inch steel I'll be "cutting washers" :D
   / Coyote Machine (this pic is for you). #3
Nice fit and nice looking. I'd rather have wheel weights than filled tires, but don't have either so far.....and apparently don't need either since I'm getting along fine as is.
Cheers,
Mike
Cheers,
Mike
I have both,filled rear tires plus the wheel weights.We heat with wood pellets the skids are about 2,000 lbs each so the extra weight is nice.I also add my 1,000 lbs ballast box when unloading for safety reasons.
If I remember correctly about 82lbs.per side.They fit R4,s also bought my set from Michigan Iron and equipment.
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2006 USH BOAT & 2012 TL (A56859)
2006 USH BOAT &...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2019 FREIGHTLINER SD122 DAY CAB (A57880)
2019 FREIGHTLINER...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
