I Mangled my Winch Cable. Replaced it.
/ I Mangled my Winch Cable. Replaced it. #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Some how I lost a snap ring on my snatch block. The sheave moved over enough to allow the cable to fall between the sheave and the frame during a pull. So the cable ran on the pulley shaft rather than the 3 1/2" diameter sheave. When you pull a wire rope around a small diameter with a lot of friction it comes out looking like a cork screw with lots of broken wires. Yes that stain is blood.
I had to replace the cable. I pulled the old cable out and strung it in a straight line across the lawn. Disconnected it from the clamp on the drum and clamped up the new cable. If you want to make a clean end or cut on a wire rope just cover a section with tight wraps of black tape then cut the cable right thru the tape. You can use a hack saw or cut off wheel.
There is a right way and a wrong way to put a new cable on any winch drum. Done right the cable lays up nicely in even wraps. Done incorrectly you put twists into the cable and you have to fight with it to get it to lay up evenly. It acts like a coil spring that wants to unwrap when you take the tension off it. The new cable will come in a coil or spool. When filling the winch drum the supply spool or coil has to turn in the same direction as the winch drum. Both CW or both CCW. You feed from the top of the spool/coil to the top of the drum or bottom to bottom. The cable makes a general "U" shape rather than an "S" shape between the spool and drum. This is what I mean.
This is my set-up
I connected up the tractor and powered the new cable on. I used a gloved hand to squeeze one side of the plywood spool to keep tension on the cable as it wound on.
After the new cable was all on the winch I picked up the end of the old cable laying on the ground, put it thru the hole in the spool, and loaded the spool with the old cable. The cable, hook, and sliders dragging in the grass provided enough tension as I turned the spool by hand. The spool now loaded with the old cable.
Before I cut the end to get my sliders and hook I took a 3' piece of fence wire, bent a 6" rt angle on one end. Laid the 6" end along the cable and wrapped the wire over itself.
Twisted the two ends of the fence wire together and cut the wire rope. I used the fence wire to hold the cable on the spool. If you ever had a bunch of loose cable to deal with you will know why I showed this.
Then I finished the end of my new cable by putting on the sliders and hook.
gg
/ I Mangled my Winch Cable. Replaced it. #2
For as strong as wire ropes are they are damaged very easily if not used correctly. I don't have any experience with logging winches so this might be a dumb question but why not use synthetic winch rope? Will it not stand up the the dirt/debris/abuse a logging winch sustains?
/ I Mangled my Winch Cable. Replaced it. #3
Gordon,
Great info. I also had a pulley fail on me 2 weeks ago. The snap ring somehow came off and the 2nd cover fell off when I started the pull but the cable stayed in the groove.
I really need to bite the bullet & buy the self release pulley. I buy "disposable" pulleys. They are rated for 25k pull. The store I get them at are $22 each. They work for about a year before they fail. I finally got a little smarter after this failure & bought 2.
/ I Mangled my Winch Cable. Replaced it. #4
Google 'Flemish Eye' to learn how to put that into the end of your cable. Not hard to do with a little practice and it is MUCH stronger than just using clamps.
/ I Mangled my Winch Cable. Replaced it. #5
I saw a wrecker that had mangled its winch cable. I'm thinking it's no longer but, but to my surprise they straightened it back into shape. They took 2 pieces of wood and clamped tightly around the cable. Then they simply wound the winch back up pulling it through the clamped wood. Again, I was surprised.
Well if they had many broken wires in their cable like mine it would be foolhardy to keep using it. At least in my book.
Mysfyt, ( Miss-Fit?? :) ) I can use that old cable to make up some slings or chokers and practice the Flemish Eye.
gg
/ I Mangled my Winch Cable. Replaced it. #7
I've always found these rather elegant as a method of wrapping, but I've never tried making one.
I think sharp rocks, the ground in dirt, and general abrasive abuse would be a definite problem. I know they use synthetic cable/rope in some portable winch applications because of the weight and handling advantage. Some tractor logging winches now come with a wire rope cable that has a synthetic core. I have heard a few isolated complaints about breakage but don't know if it is really due to the core or just misuse.
gg
/ I Mangled my Winch Cable. Replaced it. #9
Wallenstein switched to using a swaged bullet end and putting a single midget on the cable, so you can use the winch rope as a choker. It's a nice idea in theory, but I'm not about to drag the end of a 165' cable with a swaged end across the dirt under a log if I can avoid it. I got cable chokers to use for skidding because they're substantially lighter than chain, and they're $20 to replace. I'll chew up a choker before I grind off the end of my tow line.
/ I Mangled my Winch Cable. Replaced it. #10
------------> PROPERLY installed saddle clamps are "as strong" as the full diameter wire rope, so you can't get any stronger than that.
SR
/ I Mangled my Winch Cable. Replaced it. #11
SR
I respectfully disagree. I tested saddle clamps vs Flemish eye using an overhead crane and the back end of a forklift for weight. It wasn't even close to being a contest.
/ I Mangled my Winch Cable. Replaced it. #12
Perhaps your test was better than mine? I tested them with a drag line crane and also behind a D7 I had....never had a problem with saddle clamps...not even one...
SR
/ I Mangled my Winch Cable. Replaced it. #13
nice video! learned something new!
i have tried just the clamps. *meh* good tug and cable would wiggle themselves out of clamp. i was not doing the weave!
an additional note. "nut sure what they are called". but had some problems of cable "pinching" and then breaking. the end of the loop, i placed a U shape piece. so hook, other cable, what ever going through loop. hit the back side of the U, vs directly rubbing on cable. i ended up using another cable clamp. to stiffen things up. so the U shape piece would not fall out and get lost.
/ I Mangled my Winch Cable. Replaced it. #14
SR
Ironically, it was a drag line crane owner that taught me the Flemish eye.
When I did logging (many years ago) we didn't know the Flemish eye trick and made up our cables like you. We didn't have any problems either. But from a safety standpoint, I'm going with the eye.
/ I Mangled my Winch Cable. Replaced it. #15
Nice job. When I ruined the cable on my 15k winch on my truck I replaced it with synthetic. Used it about three years with no issues before I sold the truck. It was a lot easier to handle and showed no signs of wear. I was careful when winching though never really rubbed the cable on anything but it got plenty muddy.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
