Mini rod puller rear
/ Mini rod puller rear #1
ch059
Harrisburg,pa
mini rod
I have heard pro's and con's regarding full spools for mini rod pullers. My intent was to use a chevy 10 bolt rear I have with a full spool and aftermarket axles. My concern is lack of control if one side hooks better than the other. Would a posi set-up be better? Input and comments please.
/ Mini rod puller rear #2
Well the full spool is the strongest.
Can you use steering brakes with a posi?
/ Mini rod puller rear #3
You need an open differential to steer with the brakes, posi or spool will not work. What clubs are running minis? Pulled big block minis with keystone mini mods many years ago.
I pull with Rude Dog Puller. The track we pull at is in Newberrytown ,Pa. Just south of Harrisburg. We just started a class for mini rod pullers, so far there are 3 pulling 4 more being built. cu.in limit is 410 naturally aspirated.
Brutismax I understand the concept of the brakes on a spool. but why are guys welding the gears. Are the basically doing the same as a spool
/ Mini rod puller rear #5
they can't steer it if it's welded. cheap way of doing it
So if I have a chevy 10 bolt with a posi set-up I should use it. correct?
/ Mini rod puller rear #7
I wouldn't, how are you going to steer it with the front end off the ground
Ok, maybe I'm being a little thick headed, or I'm just missing the point.
If you use a limited slip your not getting all your power to the track.
If you use a spool or weld the gear your not going to be able to break steer and the same with a posi set-up.
What am I missing to be able to use break steer or is it a coin toss.
I would pick posi. or spool
/ Mini rod puller rear #9
Posi or spool is not what you need. Minis have individual brakes on the rear so you can steer with the front end in the air. We and everyone else in our club ran open differentials, under power both wheels will pull. A 10 bolt is not going to last very long behind any serious horsepower. If you are staying with a small block use a 9 inch ford rear and you wont have any trouble with it. Cheaper to do it now than find out later.
/ Mini rod puller rear #10
look on pulloff page or midnight mistress pulling site, they have for sale pages. see if you can buy rolling chassie be much cheaper than building.
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2005 CAT 140H MOTOR GRADER (A67714)
2005 CAT 140H...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2002 MACK RD688S ROLL OFF TRUCK (A67714)
2002 MACK RD688S...
2018 FORD TRANSIT KUV (A67714)
2018 FORD TRANSIT...
2007 John Deere 4x2 Gator (A64912)
2007 John Deere...
