Whereo check the hydaulic Fluid on Ck25/C27--I have lost my owner's manual
   / Whereo check the hydaulic Fluid on Ck25/C27--I have lost my owner's manual #1
ustmd
Manor, TX (outside of Austin)
Kioti CK27 HST
Okay, I am an idiot.
I can't find my owner's manual.
Where do I check the hydraulic fluid level at?
Thanks,
   / Whereo check the hydaulic Fluid on Ck25/C27--I have lost my owner's manual #2
Standing at the back of the tractor, left side of the pto output.
   / Whereo check the hydaulic Fluid on Ck25/C27--I have lost my owner's manual #3
There should be a yellow plastic like, I guess you can call it a knob, for the top of the dipstick that seats into the top of the dipstick tube as Amvcane advised.
   / Whereo check the hydaulic Fluid on Ck25/C27--I have lost my owner's manual #4
The knob thingee is red on my CK30 . Very easy to find though.
   / Whereo check the hydaulic Fluid on Ck25/C27--I have lost my owner's manual #5
Where he said, yellow dipstick, red is the fill port. It's also the tranny fluid tank (same fluid, same tank).
Thank you all. I thought that is what I was checking, but wanted to double check. Troubleshooting a problem (RPMs bog down/tractor stalling when hydraulics are being used) to make sure it is not a simple issue before sending the tractor to the dealer.
Looks like the tractor is going for a ride.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2015 Chevrolet Equinox SUV (A56859)
2015 Chevrolet...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
flooring (A55758)
flooring (A55758)
