Simple, cheap and useful?
/ Simple, cheap and useful? #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
I always add a small, inexpensive (but waterproof) LED voltmeter to my tractors. This one cost $7 on Amazon, requires simply a hole, a switched 12V power source, and a ground. It tell me how the charging system is working, and if the battery is okay. Better than the idiot light, I think.
/ Simple, cheap and useful? #2
Nice. Is that surface mount or did you cut into dash cover? If you did cut, what did you use?
/ Simple, cheap and useful? #4
Simple, cheap and useful.... describes me to a tee!
Installation was easy, in the sense I carefully scribed the outline of the opening needed in a section of the plastic instrument cover that didn't have any obstacles behind, then used a sharp utility knife to cut, and cut again, until I had the required opening. The meter has spring tabs on the sides, and I applied a bead of silicon around the meter to make sure no melting snow or rain got behind it. The plastic of the dash is tough but not brittle.
/ Simple, cheap and useful? #6
That's a real good idea and you did a neat installation. Knowing your charging voltage and the voltage before you crank tell you a lot and can save you some grief if you pay attention. :thumbsup:
/ Simple, cheap and useful? #7
Great idea, can you supply the link for it.
"Great idea, can you supply the link for it."
Sure- just go to amazon, and enter Drok waterproof voltmeter. It is still $6.99 at Amazon. I have Prime, so I don't know about any shipping costs... sorry.
Amazon.com: DROK® 0.40" Waterproof Digital Voltmeter DC 2.5-30V Voltage Tester Red LED Panel Display Car Auto Vehicle 12V 24V Battery Power Monitor; Little DVM Outdoor Gauge for Solar System; Two Wires mode, Self powered, Measuring Lithium Battery, 18
I looked at eBay, and they cost more, so I didn't link them there.
/ Simple, cheap and useful? #9
I have the same ones installed on both my tractor and my side-by-side. The tractor spends its nights in the garage but is used periodically in the rain/snow. The side-by-side is generally exposed to all weather and since its cover tore up has been uncovered for six months. Both appear to live up to the waterproof claim in over a year of testing. My only complaint over that of a traditional meter movement is that they are difficult to read in even moderate sun, but shading with your hand makes it possible.
I installed them after a wayward branch caught under the side-by-side causing a charging wire to pull from its connector and it died after an hour of running spark just off the battery. A meter would have warned me and made the diagnostics faster. Now, I frequently run 12 Vdc water pumps, hydraulic pumps, power inverters, etc and monitor charge condition on the fly. Very good move, and very cheap.
Dan
/ Simple, cheap and useful? #10
I ordered one, thanks for the link.:thumbsup:
/ Simple, cheap and useful? #11
Thanks Varmint, just placed my order also.:thumbsup:
/ Simple, cheap and useful? #12
Sorry to revive this and make it a zombie. In my post just above I said that after a year the voltmeter on the side by side exposed to the weather seemed to have lived up to the waterproof moniker. Well maybe six months after posting, the meter would get fluky after it rained out and read false voltages ranging from 0.3 Vdc to 30 Vdc even though the actual voltage was say 13 Vdc. After a day or two of dry weather it would read fine. Now, two years later, it hardly ever reads properly. The one on the garaged tractor still works okay. Conclusion: not waterproof.
JAYCO BUMPER PULL CAMPER TRAILER (A63569)
JAYCO BUMPER PULL...
72� United Box Blade (A64047)
72� United Box...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
Adams 8 Ton Blender (A63118)
Adams 8 Ton...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
