73F @ 7:30AM. Sunshine and a few clouds. A stray afternoon thunderstorm is possible. High 101F. Winds WSW at 5 to 10 mph. The highs will be in the hundreds here all week, so I'll be working inside jobs most afternoons.
I had a pair of swallows trying to start a nest under the patio eves last week, Eric. Thought it mite be kind of nice to be able to watch the goings on, then noticed the mess they were making on the ground. They didn't seem any too friendly, either. Next thing you know the garden hose came out and all the mess was gone, and haven't seen 'em since.
Hope your neck feels better soon, wngsprd.
Don, sounds like you picked a good name for Wipper!
Farmer, the manufacturer of that gearbox has a problem. Is an improved part available? But at least you can get a replacement, and fix it yourself. Nothing like having to wait on a repairman!
Got in a few hours of spraying on the RTV yesterday, and the temperature gauge didn't even move. Turns out the radiator fan is driven off a relay that is triggered by a temperature sensor on the engine block, and both the trigger and power circuits are fused. A few weeks ago another fuse popped (can't remember why) and lacking a replacement, I got out the repair manual to find one that wasn't being used. One was labeled "work light" which this machine doesn't have, so I used it. I should have also looked at the schematic, because that fuse also powered the relay trigger from the temperature sensor. By now I have spare fuses in hand, and slipping one into place got the fan going again. Only took a few hours of probing and taking things apart to figure that out though. :confused2: Hope to finish up the spraying this morning. Yesterday the diff lock came in handy several times, as the bottom reaches of the hill are rough with rock and loose dirt. With the extra weight of the spray tank all the way in the back on the dropped tail gate, the front wheels were in the air a bit on more than one occasion. :shocked: Just the thing to keep the job interesting, but at least I didn't get stuck!
Happy Monday everyone!
