Kuhn 4100
/ Kuhn 4100 #1
L121andrew24
Swansea, Ma
John Deere 4440
I need to transport this rake from Pa to Ma. It is over 13ft width. I was looking at the arms and I could not figure out how to remove them. Any advice would be apriciated! Thank you.
/ Kuhn 4100 #2
The tine arms are held on the shafts by paired rollpins. Probably a 12MM with a 7MM driven inside it. I also thought the 4000 series rakes had a few tine arms with quick release pins for easy removal of enough to get to legal widths. You can be sure there is some easy way to get down to 8 feet; Kuhn is made in Europe (France) where travel laws are MUCH more stringent than here. Nobody is going to drag a 13' wide rake down a road in the EU.
/ Kuhn 4100
I see the roll pins, how do I go about taking them out, do I just do a punch and hammer?
/ Kuhn 4100 #4
Roll pins can be punched out but careful not to "brad" the ends. Ideally, use a specific roll pin punch. It's designed for these tasks. It looks like a regular punch but with a stepped end and a flat shoulder designed to engage the roll pins. They make different sizes and are fairly cheap and can be found at most fastener or decent tool shops. But in a pinch you can use a flat ended shaft of the appropriate size. Use some penetrating lube first.
/ Kuhn 4100 #5
I agree and these are very good roll pin punches with protrusion in the center so punch will be centered in roll pin.
(4) TRANSPLANTER UNITS FOR PARTS (A64278)
(4) TRANSPLANTER...
2101 (A65055)
2101 (A65055)
2017 Ford F-250 4x4 Crew Cab Pickup Truck. (A64194)
2017 Ford F-250...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2021 CATERPILLAR 279D3 SKID STEER (A65053)
2021 CATERPILLAR...
