Ford 1210
/ Ford 1210 #1
ALB
Cumming, Georgia
Ford 1210
Oil pressure light came on. I jiggled the wires at the bulb and it went off. Now I don't know if i have pressure or not. Where is the oil pressure sensing unit located? I'd like to test the oil pressure.
Thanks
/ Ford 1210
replaced the oil sensor and all the light bulbs and now everything works.
Question: when it is running the water high temp lights flickers. after a while it doesn't come on.
Any idea?
/ Ford 1210 #3
Welcome aboard! I'd try going over the connections first. I had trouble with the battery not charging on mine. Turned out to be dirty contacts in a plug under the instrument panel. I SHOULD check, clean and use some Penetrox or equal on all the connections before Winter.
My 1210 acts a lot larger than it looks. It's a scrappy little thing. This past Winter a couple friends used it with a 5' rear blade and they were really surprised with its capabilities.
/ Ford 1210 #4
Any idea?
My 1200 water temp lite started coming on almost immediately when I started it up, very dimly. After checking belt tension etc. I replaced the sender and put in a new thermostat just to be sure , no more lite. Except if I don't keep the screen in front of the radiator clean from dust and debris, I've had it only start flickering once.
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
