CT235 Fuel Injection Pump Failure
/ CT235 Fuel Injection Pump Failure #1
brotsten
Kingston,WA
Bobcat CT235
I know this is well documented, but wanted ritcheyvs to add it to his spreadsheet http://kittrellcommunitywatch.dyndns.org/Kioti_IP_Data
My tractor has 1100 hours and like most of the failures was running fine, shutoff, would not start again. Mine had two broken teeth on the gear for the #3 cylinder. It also had the gears with an unmachined spot on the unused portion that prevents rotating them 180 degrees.
I purchased 3 replacements from H and H for $52 shipped to my house. I attached a copy of the invoice in case someone else wants to use them.
It probably took me six hours total, I'm pretty slow. :). Nothing at all difficult about the job, check some of the other posts on the spreadsheet for step by step instructions.
/ CT235 Fuel Injection Pump Failure #2
brotsten:
Spreadsheet should show your update. Your pics are excellent.
How did you determine the correct gear to order from H&H?
This gets a big ATTABOY! A Canadian CK20 owner recently posted that it cost him $1800 for his dealer to replace his IP (and some of us are not convinced that IP was bad).
/ CT235 Fuel Injection Pump Failure #3
Sorry to hear of your IP failure. Good job on getting the replacement parts. Can you post your Bobcat's serial number so the date of manufacture of your machine can be included? Did you have any symptoms leading up to the failure, or did it just die, dead with no warning whatsoever?
Is it back together running well now?
brotsten:
I used the same part# from this post. The parts guy used the 140241-2700 1303 number instead of 9 411 617 148. The replacement gears (I believe the nomenclature was "Control Sleeve") have all the teeth machined in them.
The serial number is A9JY11910.
No symptoms of impending problems, the tractor had been running fine for about 15 minutes, stopped to put an attachment on and it wouldn't start. Determined it wasn't getting any fuel, pulled the stop solenoid to verify it was working and then tried shifting the rail by pushing where the stop solenoid was removed and could feel it wasn't moving. Commenced Googling...
It's all back together, running well, and I have about 5 hours on the repair.
Bullet dodged. :)
Brian
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2014 FVCG TRAILER (A61567)
2014 FVCG TRAILER...
2021 Dodge Charger AWD Sedan (A61574)
2021 Dodge Charger...
