ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,724
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
That is all my DK has..range shifter in Neutral, and it will fire right up. No seat switch, no clutch switch.. cause it doesnt have a clutch. Really handy when you need to raise up out of the seat to see the front of the forks better as they enter a pallet. If you fell out of the seat a brush hog would grind you up... So don't fall out of the seat... It would be pretty hard to do with the high back seat... but I suppose anything is possible. It won't start with the PTO engaged though.
My Kubota has an alarm that is an obnoxious high pitched whine if I leave the seat with the PTO engaged. 99% of the time my PTO attachment is a brush cutter so it's obvious if the PTO is on. But I understand that alarm. It doesn't shut the tractor off or disengage the PTO, just warns you that you've left the operator area with it still engaged. That's cool.
