Buying Advice I'm look at buying lawn tractor.
   / I'm look at buying lawn tractor. #21
here are some specs on your JD 216, compliments of tractordata.com
TractorData.com John Deere 216 tractor information
this link to a manual looks useful
John Deere 200 208 210 212 214 216 tractor repair manual - Video Dailymotion
belt replacement video (video has good info, a bit long 10 min)
https://www.youtube.com/watch?v=RhI-oKbgehs
enjoy your machine.
ck
thanks for this info... when I get back in I will open another threat in j-deere and ask all question.
   / I'm look at buying lawn tractor. #23
jagco,
I'm not knocking your tractor, just telling what I observed in my store to store visits. I never saw the particular model you got. The ones I looked at were all smaller models than what you bought.
I'm sure you'll have good luck with it.
jagco,
No problem, very please with it as I'm getting to no it. It's a big hit with my friends.
   / I'm look at buying lawn tractor. #25
When I got mine, I compared them all. The other mtd brands looked like cheap crap. I was impressed with th quality of the cub. It was made as well as any of the more expensive brands I looked at. I understand that even though cub is owned by mtd, they are built in their own factory and share no parts from the other mtd brands.
there is more crossover between the other mtd brands than you would think.
   / I'm look at buying lawn tractor. #27
I pick up the John Deere 216 runs good the tires all 4 look new and new starter.. Question 1 how do I install the deck and drive belt. Deck Ser - H047K-4578168M has 3 blades. No amp gauge not wired or broke. The light switch is where the choke is for the carb. No lights. Is the 216 4 speed with a revers. Can any 1 tell me what are the little ball levers blue in color and the blue red handle. Witch side is the brake pedal. And what is the other pedal for. "O" there's about 3" of play when i turn the front wheels is this a easy fix. "O" the tractor ser - C or 0 216K-155803N
View attachment 428835 View attachment 428836 View attachment 428837View attachment 428833 View attachment 428838 View attachment 428839
I think the pedal on the left is the clutch and the one on the right is the brake. Just like a car almost.
The play in the steering might be a problem in the steering column gears. I had a 110 a little older than that on with the same problem. I never fixed it because it looked expensive and hard to fix, and it was a pain to drive because I was always correcting the steering.
   / I'm look at buying lawn tractor. #28
If you think the steering on the lawn mower is annoying you should drive my dads truck.
Steering problem seems fix now. I loosen the nut on on the gear box and turn the notch screw in and re-grease it. working find now.
SOFTBALL & BASEBALL HITTING & CATCHING GEAR (A58374)
SOFTBALL &...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
7021 (A55851)
7021 (A55851)
New Land Honor Heavy Duty Plate Compactor (A59000)
New Land Honor...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
AIR TANK & HOSE REEL (A58374)
AIR TANK & HOSE...
