farmall m runs poorly once engine gets warm
   / farmall m runs poorly once engine gets warm #1
huzzah man
dillard MO
farmall M
I have a 1949 Farmall M converted to 12 volt.Recently it began running rough. I cleaned the fuel filters, drained the gas tank,checked the plugs, replaced the distributor cap. After all this it started and ran smoothly at idle and for a while under a load. After an hour of brush hogging it started missing again, but still idled smoothly under no load at low RPMS.
Any suggestions?
   / farmall m runs poorly once engine gets warm #2
Look for a crack in the fuel lines which allows air to enter. You won't see fuel leaking out but air can get sucked in. Is there an air vent on the filler cap which is plugged? (Just quick ideas which might not apply.)
   / farmall m runs poorly once engine gets warm #3
I would check the ignition system again, rotor, linkage movement on distributor, plug wires and other things like plugs you checked previously. When it is missing can you pull the wires on the plugs one at a time to determine which one is the problem?
Since an M has a gravity flow for fuel (with the tank up top under the hood) I doubt air entering the system is the culprit. As long as you have a good fuel flow to the carb that should not be an issue.
My best guess is a plug or plug wire is the problem.
   / farmall m runs poorly once engine gets warm #4
Might be an idea to give the choke a quick on & off pull next time it does that. Could be a speck of something in the main jet. A quick tug on the choke under load has a tendency to pull it on though. If it straightens up if for just a bit, you know it's fuel related.
I've also in the past had a speck of carbon foul a plug too. I tend to by the mid grade gas when I'm working the C's or the 656 pretty hard. Seems to eliminate some predetonation I seem to get at times with this ethanol laced gas.
   / farmall m runs poorly once engine gets warm #5
Might be an intake manifold or gasket sucking air once it warms up. Take a can of WD-40 or carb cleaner and when it is running rough spray around manifold gaskets and the manifold itself. If it is sucking air it will run great for a few seconds when it inhales a puff of something flammable vs. air and you will have pinpointed your leak.
   / farmall m runs poorly once engine gets warm #6
I would fill the fuel tank with fresh fuel and add a quart of auto trans fluid with it, this new fuel really sucks on older engines. I have seen this work a number of times. Good luck.
   / farmall m runs poorly once engine gets warm #7
This happened on an H that I used to own and it turned out to be a bad coil. Just start with the simple and no expense stuff first like cleaning the electrical connections, checking all connections are tight, etc.
   / farmall m runs poorly once engine gets warm #8
second the thought of the coil / points / condenser .... leaning more towards the points first , then the condenser then coil
   / farmall m runs poorly once engine gets warm #9
ditto on the coil my 49 cub was giving me trouble and a new coil solved it. touch the coil when it.s running rough and see how hot it is if very warm replace
Greg
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
2014 JCB 930 (A57148)
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
