rear remote issues
   / rear remote issues
I worked the tractor the past couple days and setting the top link with boxblade on ground worked much better. Thanks for all your help.
   / rear remote issues #12
If you get some .030 flow restrictors, your sloppy cylinder syndrome will go away. You can get them that fit right between the hose and your male coupler. Makes life much easier. :thumbsup:
Cool thanks. I am running 1/4" hoses and I was hoping they would help.
   / rear remote issues #14
A lot of people think so, but not really, the hole through the port into the cylinder may already be that small. You really need to go with the .030 restrictors.
You will see a HUGE difference with how things operate. You can get them from me if you don't want to shop around.
How much are they with shipping to 62898?
Cat Mixer RM-250C (A55973)
Cat Mixer RM-250C...
2010 Ford F-150 Single Cab Pickup Truck (A55973)
2010 Ford F-150...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
