What are these things called?
/ What are these things called? #21
Sorry bout that, anti-chafe tape is a generic term that I guess could apply to many tapes depending on application.
The very best, toughest, abrasion resistant tape is doubtless UHMW PE (ultra high molecular weight polyethylene) - mostly referred to as "UHMW". Handy for all manner of things where you want both low friction and high wear and abrasion resistance. Comes in varying thicknesses, you'll want something close to 5 mils if flexibility is important, as you get to about 10 mils (0.010") it starts getting less conformal, though even the thinner tape will not do compound curves as the material is just too mechanically strong to stretch much. Do a search on Amazon for UHMW tape. Oh, also it's available with either acrylic or rubber based adhesives . . . in most cases, acrylic adhesive is stronger.
bumper
Nice information. Often I've used military duct tape or aluminum tape for a "liner" on sensitive areas like wiring in exterior situations or finished vinyl or duct insulations. I would think hydro hoses would also benefit from a chafe tape concept.
These UHMW types of tape . . do they stay when Wisconsin winters do their worst and wide temp changes from winter cold start to operating temps develope?
Another attached picture with parts numbers - no prices yet. CouplerColour.jpg
/ What are these things called? #24
I've never heard of chafe tape. Is it like a teflon tape or a vinyl or ?? Where do you get it?
I've found tie wraps/zip ties to be both a blessing and a curse. I often reuse them over and over . . and I was surprised many don't know how . . especially on the heavy duty versions used in heating and air.
On the other hand many see zip ties as harmess because they are plastic . . yet as you've mentioned also . . they can me quite abrasive (or cutting) themselves in the heavier versions . . and quite abrasive when dirt mixes with them.
Some of the heavier duty ones I've often used as a makeshift rasp or saw . . As their long edges can be very sharp and durable in thicker sizes . . and cut like tin or copper if not careful.
Going back to chafe tape . . is it available in different sizes or weight grades ?
We use two different types of chafe tape at work. One is clear, about 1/16-1/8 thick and has a soft plastic feel to it.
The other is stretchy and is red. We wrap the edges of landing lights with it to keep them in service longer from vibration that will help the bulbs burn out. It isn't real sticky, until you stretch it to make a tight wrap.
hugs, Brandi
/ What are these things called? #25
Another attached picture with parts numbers - no prices yet.View attachment 429808
I'd call them a coloured 'split ring' and I'd imagine that they would come in standard diameters to match standard couplers.
I've looked at the "ENZED" on-line catalogue and all that they have is the standard dust-cap.
/ What are these things called? #26
hugs, Brandi
Brandi,
Are you talking about "chafe tape" as is a tape with sticky on one side only that is applied to one surface to prevent wear, or reduce friction between that surface and another that rests upon it but can vibrate or move in relation to the first surface?
Not trying to be argumentative (honest :c) but the first tape, the clear one, sounds like 3-M VHB (very high bond) clear acrylic double sided tape. It's commonly used for mounting acrylic lenses, glass, and some other plastics. I use it to make the MKIV "high tech" yaw string for gliders. The second, "red tape" sounds like one of the silicone "self vulcanizing", stretch then it sticks to itself tapes. Since this tape has a broad temperature range, it would be well suited for wrapping the edges of landing lights, even though silicone, as a category, has poor resistance to abrasion. In the app you mention, this would not be a problem as the light is securely mounted and the tape is acting as a cushion to damp vibration.
BTW, I've gone to all LED lights, including strobes, in my Husky aircraft. Far better performance than incandescent, less current draw, and supposed to last up to 50,000 hours - - I don't think the plane will last that long!
/ What are these things called? #27
Those are called Dust Caps. Dust Caps for hydraulic couplers do come in various sizes, i.e. 1/2", 3/8", etc.
You would think that every tractor dealer around would have them on the counter for give-aways. That's just not the case! Heck - at TSC yesterday I looked at some, having missing on my Kubota, the dang things were $2.50 EACH. Double that on Amazon!!! I passed on that.
If you find a good 'reasonably priced source' for them, please post it on here or PM me.
As far as scratch-proofing wire ties, I - Like Stacey David on Gearz suggested, I smooth mine with a cigarette lighter. Works great and simple.
/ What are these things called? #28
In the past hydraulic couplers had colour coded dust caps but I am now seeing what appears to be colour coded wraps (metal or plastic) on 2 ends of the couplers - see photo.
Can someone tell me what these coloured wraps are called and are they size specific?View attachment 429715
Reference my response and the OPs original question. What is everyone using for dust caps/plugs when disconnected? They are permanently mounted and color coded on my BX. I disconnect a lot so they get used a lot and everything gets connected right. If you want to do away withe the caps/plugs why not use colored electricians tape. Solves all those other problems with the make dos discussed here.
Ron
/ What are these things called? #29
Brandi,
It is not double sided tape.
hugs, Brandi
/ What are these things called? #30
Ron
I've tried that, Ron, but the excess hydraulic fluid from disconnecting un-glues the lecky-tape. Co-responding number of tiewraps or coloured ones last longer, I've found.
I do use the provided dust caps on the female ends, but both are red.
/ What are these things called? #31
Red dust caps??? Where do I get some . . They'd blend right in with massey color for the fel zerks and mmm zerks.
/ What are these things called? #32
Well, AxleHub, I suppose that I should have said that they were originally red... they've faded to pink now due to UV rays.
And that's saying something about the intensity of the sun's rays here in Tassie as the tractor is in the shed when not in use. 250hrs now.
My black JD ballcap is 'tan' coloured now, except for where the ear-defenders rest. :eek:
/ What are these things called? #33
TSC has red dust caps. Two for $4.49 yesterday.
/ What are these things called? #34
These little HF cutters will cut the zip ties off flush.
Micro Flush Cutter
Lowes used to sell a Kobalt pair that were nice, too, but stopped a couple of years ago.
/ What are these things called? #36
I know Parker has them in several colors for their QCs. My BX has 4 different colors with the Parker QCs. They go on the hose before the QC so are semi permanent and don't get lost. When I bought 2 QCs to make up my pressure gauge the cap/plug came with them.
Ron
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
2008 JOHN DEERE 700J LGP CRAWLER DOZER (A62129)
2008 JOHN DEERE...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
2007 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Bucket Truck (A60352)
2007 Ford F-750...
