Oil & Fuel Adding a Spin on Racor filter to a BX25
   / Adding a Spin on Racor filter to a BX25 #171
I plumbed mine with fuel lines that run up front to the Racor from the tank, them back to the fuel pump, so the Racor is plumbed before the pump. At first I plumbed it after the pump just because it was easier and then on the advice of others on this board changed it.
   / Adding a Spin on Racor filter to a BX25 #172
:thumbsup: Now to get Kubota to realize that their factory BX filters are a cruel joke, and they should be putting something a little better than a $5 snowmobile filter on a $20,000 tractor!!!;)
Would the B Series Kubota tactors also benefit/"need" a similar filter improvement "fix"??? Or does the B series have a better factory set-up? Thanks Tom R
   / Adding a Spin on Racor filter to a BX25 #173
You can see the B series filter here.
Even with the Racor up front, you still need a pre filter for the fuel pump don't you to prevent dirt fouling the pump?
The lift pump could be susceptible to debris, but im willing to take that chance (its a relatively large clearance, non percision pump). Its not that expensive of a part if it goes. Its the injection pump to be worried about.
The B has a considerably better filter, however, its still not as good as the ones were installing on the BXs IMHO. Considering that, the B could do with an upgrade too, but its not nearly as bad out of the box as what comes stock on the BX.
   / Adding a Spin on Racor filter to a BX25 #176
Every fuel pump I've ever pulled out of a vehicle had at least a fuel pump strainer before the pump. The added hose I used to run from the tank to the fuel filter added up to about 2.5 feet and my cost on that would be around $2.00. The photo I attached is the crap that came out of the filter on my BX at 70 hours. Imagine that stuff going through your pump.
I bet you won't replace your pump for $2.00 Then there's the down time on your tractor because of it. They usually don't brake down in the shop either ;)
AMEN to THAT Paul...!
PaPow
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
2500 GALLON POLY STORAGE TANK (A57192)
2500 GALLON POLY...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A55851)
2025 JMR 36in...
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
