Oil & Fuel Adding a Spin on Racor filter to a BX25
   / Adding a Spin on Racor filter to a BX25 #161
Good install.. You'll be happy you did it. You really got to try to get the filter as close as possible to the loader support tube to clear the tire, thats really the only thing to watch out for.
Thanks Scooby and you are exactly right. My first attempt I had it too close and as I was going up a hill while making a hard left, it caught the valve at the bottom of the filter and slightly bent the bracket. Luckily I was going slow and stopped right away. I redrill holes and made sure I was far enough away. Initially I thought had the clearence but I guess not. thanks again for all the help.
Thanks Scooboy and you are exactly right. My first attempt I had it too close and as I was going up a hill while making a hard left, it caught the valve at the bottom of the filter and slightly bent the bracket. Luckily I was going slow and stopped right away. I redrill holes and made sure I was far enough away. Initially I thought had the clearence but I guess not. thanks again for all the help.
:thumbsup: Now to get Kubota to realize that their factory BX filters are a cruel joke, and they should be putting something a little better than a $5 snowmobile filter on a $20,000 tractor!!!;)
   / Adding a Spin on Racor filter to a BX25 #163
Here is my Racor. I made a stainless steel bracket that slides in between the front left floorboard mounting area. Just take out the one carriage bolt holding the floorboard, slide in the bracket, and but the bolt back through and tighten it.
nice! been wanting to add one of these for a while - this looks like a good protected location. tough to find free space on those little machines.
   / Adding a Spin on Racor filter to a BX25 #164
I really struggled with mine when I put it on. My fabrications skills are a little weak but you pretty much have to mount it as far back as possible or the wheel will get it. I also had mine to far forward and the wheel actually open the drain valve on mine while I was mowing.
   / Adding a Spin on Racor filter to a BX25 #165
Not sure if that would work for the newer 70 series as they have the brake on the left. But it works like a charm for my 60 series BX25. Tucks in high and tight BEHIND the loader arm. No tire interference issues at all.
   / Adding a Spin on Racor filter to a BX25 #166
Any of the guys who installed the Racor filter have any issues with the filter leaking out of the valve at the bottom. Leaking and don't want to tighten the valve too much in fear of braking it. It was fine for the first month.
   / Adding a Spin on Racor filter to a BX25 #167
I've had zero problems with mine and have not needed to replace the filter yet after I think two years. No crud/water accumulation in the bowl. I've just burped it a few times since I was already down there looking and it seemed like a good idea.
No problems here. You should be able to make it snug enough by hand. No dirt or anything preventing a good seal?
   / Adding a Spin on Racor filter to a BX25 #169
Same here.
   / Adding a Spin on Racor filter to a BX25 #170
Even with the Racor up front, you still need a pre filter for the fuel pump don't you to prevent dirt fouling the pump?
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
Toro Z Master Mower (A50322)
Toro Z Master...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
