Quadco teeth?
/ Quadco teeth? #1
redprospector
Cloudcroft, New Mexico
Fecon FTX 90 /Pieces of an ASV 4810 / JD 440b skidder / JD 450b dozer / Bobcat T320 / Hydro Ax 311c
Anybody running Quadco teeth on their mulcher? If so, what do you think of them?
/ Quadco teeth? #2
I switched about 2 years ago when the carbides wore out. Love the quadco planer style in the deep woods with no rocks or metal here in FL. They are very well balanced also.
/ Quadco teeth?
We've got plenty of rocks here, but I was looking at using the planer teeth on select jobs that didn't have much rock, and changing back to carbide when necessary.
How many hours are you getting out of them before they're done?
/ Quadco teeth? #5
About 200 hrs per side. Keeping it out of the dirt is key as you already know.
/ Quadco teeth?
Have you tried Fecon's knife teeth?
No, I haven't tried any of the knife teeth yet. Just exploring options.
I would like to hear from anyone using Fecon's knife teeth too though.
/ Quadco teeth?
Well, I guess that I've decided that any kind of a "knife tooth" around here is going to be a futile effort. :(
I'm going to be cleaning up some more land that was devastated by a forest fire. There are several problems with a job like this. One is that when a catastrophic fire comes through all of the organic soil is burned up, leaving only rock exposed on the ground. It's hard on any cutters that you want to use. The second problem is that the Western White Pine (we call it sugar pine locally) has a lot of heart wood that gets really hard, too hard to grind up with carbide tools. The third problem is specific to this job, and that is the fact that it is a 5 1/2 hour round trip to haul the logs to my property on my gooseneck and pickup (the big trucks aren't interested in hauling it).
I was hoping against hope to be able to use knife teeth to chip up most of these logs, and only have to haul off the largest of them. But after walking through the job again, I think I'd go through a set of teeth a day if I tried it.
Oh well, It was a thought anyway. I guess I'll just keep on keeping on the way I've been going.
/ Quadco teeth? #8
Andy, have you tried the Fecon stone teeth? I run a larger version on my old style Fecon rotor, run them through all kinds of rock and hard timber and can't get to even smoke up. They are hopeless in soft wood, just to aggressive. :2cents:
/ Quadco teeth?
Thanks Tony,
All I've used is the standard double carbide's. They just seem to be a little slow in this stuff (well, maybe more than a little). I may look into the stone teeth.
/ Quadco teeth?
It's the old style, it's an 06 model.
What is the difference between the single carbide, and the stone teeth?
/ Quadco teeth? #12
The best way to describe the single carbide teeth is that they are half a double tooth with a left and right combination, one row all right, next row all left. The teeth I use is the same width as the doubles but with one big mother tile and the tooth is forged steel not cast. I have got the last ones available in Australia. 300 is the smallest order they will take and I'm to old to wear out 300 teeth, they last 1500-2000 hrs
/ Quadco teeth?
Thanks Tony,
That sounds like it might be what I'm looking for.
I just hope I don't have to buy 300 of them to get any. :eek:
/ Quadco teeth? #15
I have quadco adaptors with buncher teeth on them . Very aggressive , bring along a spare set of belts . AHWI (fecon) 125 head
Container W/Side Window & Door (A62183)
Container W/Side...
2018 John Deere 6130M (A62180)
2018 John Deere...
SDlanch 20'x30' Steel Carport (A62183)
SDlanch 20'x30'...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2011 Case IH Magnum 315 Tractor (A64047)
2011 Case IH...
Container W/Side...
