Ford LGT Crawler Conversion
/ Ford LGT Crawler Conversion
Got the power steering pump bracket and tensioner installed today.
Going to pick up some hose and fittings in the morning, I'm anxious to get it done.
/ Ford LGT Crawler Conversion #22
Anything new??? Love the build
I've been working on the reservoir. Just fixing up some pin holes, and should have it painted and in later today, hopefully.
EDIT: Just ran out of O2 for the torch, hopefully I can talk the missus into picking some up on the way home.
Picked up some O2 and got the reservoir finished up, painted and installed.
Also have a picture of the push blade piece.
Push blade is finished. I've been working on the hydraulics. I got a 3 spool control valve on sale last week, but broke the camera before I could show it installed.
/ Ford LGT Crawler Conversion #26
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=421564"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=421563"/>
Looking awesome so far
/ Ford LGT Crawler Conversion #27
Anything new
Finally found a new gas cap for it, and spent yesterday afternoon soldering and testing the tank. Got it painted up last night. Picked up a new camera the other day so I'll have some pictures soon. Still waiting for the right hoses to show up at Princess Auto so I can finish the hydraulics. Now I have to start thinking about how I'm going to get it off the table.
I'll post some pics later today.
/ Ford LGT Crawler Conversion #29
A bunch of people
A bunch of people
This beasty weighs over 1700 lbs now. I've got some 10" C-channel, I'm going to weld angle iron to it for the grouser to bite on and build ramps. I've got some 4" angle steel for the legs.
3 gang hydraulic control valve
Figuring out how to route all the hoses
Hydraulic reservoir is installed
Complete with oil cooler
And the gas tank is painted, just need to get some tank sealer before I install it permanently.
I picked up a couple more hoses today, At least the drive across the city wasn't a complete waste, unlike the John Deere dealer.
All front hydraulics are installed and tested. Travel speeds are good, and faster than I expected from an automotive power steering pump. Test motor was 1/2" electric and everything worked fine.
Just have to install the spiral wrap and reverse the lift cylinder connections and it's good to go. Hope to have a video up soon.
thanks
I wanted to be able to grease the rollers occasionally. With the difficulty of getting at each and every roller, I decided to grease the wear rail, since every roller will run on it.
The grease guns are connected to the rails with hoses. A few strokes every so often should keep the tracked well lubed.
/ Ford LGT Crawler Conversion #36
Get it down and running yet
Soon, Soon, Need to find the right ignition switch, or combo of toggle switches, to get the electrical finished up, and figure out how to mount the stupid LED grommet-mount marker lights, without the grommets. That and had to make a pedal for Fpr/Rev.
/ Ford LGT Crawler Conversion #38
Saw your videos about the plow and rippers and your pump. Looks really nice. One thought for paint although you already did a bunch. What happened if you did a few different colors. Like tracks/plow/ripper black colored. My opinion is that that would really make it a looker
I thought about it, I was going to go blue and white, since the decals are white, but then I decided that one color was easier to maintain, only 1 spray bomb to carry around. I also think the white decals should be enough to set it off, if/when I can get some up here. Attachments can be repainted later too. Right now I just want it done.
And it's sooo close. I should have all the electrical stuff finished today. I need to upholster the seat, and get the decals. I have a buddy coming over next week to help me get the ramps in place (12" C-Channel is heavy)
/ Ford LGT Crawler Conversion #40
The ramps to take the tractor off the welding cart? You are right. Maybe the decals will help. I do love the shade of blue you are using though
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
1057 (A63291)
1057 (A63291)
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
