Rock rake..
   / Rock rake.. #1
hunt4570
Elite Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
Some may call it a landscape rake but to me its a rock rake.
Anyway, we just moved cross country and sold my tractor and implements before we moved cause they wanted too much to move them. So when I got here I got a new and improved tractor ,L3540, but when I bought my rake.. my most used implement by the way, I bought me a cheapo at Agrisupply. Nothing against Agrisupply mind you, it was my decision to go cheap.
Well after a couple months of fighting the stupid thing I sold it and bought a TSC rake.. was going to get another 6 footer but splurged and went with 7'. Hope its not too wide, but now I can angle it and still get out past my tires!!
I Don't know what the deal was with the cheaper one but it just never seemed to work as well, weight, more likely geometry, but what ever, it never did function quite properly.
Used the new one for the first time today and it worked just as I remember a rake working...
WHOOHOO!!!
El Cheapo...
And the new TSC one.. 7 footer, oh yeah!!
   / Rock rake.. #2
Those things work really, really well, for a variety of tasks and that, in my mind is what makes them so great. But I would (personally) not call them a rock rake. They are a spring tooth rake.
   / Rock rake..
They do work very well for a variety of tasks, which one of their best tasks is raking up large rocks out of fields... hence rock rake.. Which is what I call them.
   / Rock rake.. #5
You would destroy one of those on our rocks. I guess rock size is based on geography and somewhat subjective.
   / Rock rake..
Now let us see some pic's of rocks you are raking!
Well I'm in South Carolina now and not much in the way of rocks here, mostly sand.. you would have thought we moved to the beach or something!
I got my start raking rocks when we lived in Texas and Oklahoma, depending where you live in Texas you know what I'm talking about.
Now its mostly used for dressing the driveway and raking up sticks and pine needles.
   / Rock rake..
Yes that is correct, see,size DOES matter!!:laughing: The rocks I started using on were baseball to small cantaloupe sized.
   / Rock rake..
So this thread has gotten a little off course, it wasn't intended to be about what I call this device, but more about the difference in the quality of the different implements.
While the first rake I bought here looked just like a rake, the function wasn't so good. Yes it worked and did its intended job, just not real well.Again I think some sort of geometry was working there..seems like there wasn't a lot of movement back at the tine tips. I couldn't pick it off the ground more than a couple inches, but if I rolled over a hump in the ground it would pic the rake off the ground.. weird!! A lot more range of motion with the new one...
   / Rock rake.. #9
So this thread has gotten a little off course, ...
That happens on TBN????? I NEVER knew that!! :laughing: :laughing: :laughing: :laughing:
Congrats on your new toy...er, tool!! :thumbsup:
   / Rock rake.. #10
I cant see how the rakes would differ in the ability to raise or lower. If it wouldn't raise, then you needed to adjust the top link shorter, assuming that your lift arms were raising full up. Not lowering, could have been the draft control OR where you stopped the position control lever.
Note: One rake might have a longer tail shaft than the other one so it may go higher, but still height of lift is largely determined by the top link length. Also the top link length will determine how the tines hit the ground, just like a straight blade, longer top link will make it dig in whereas a shorter one will make is skim the ground (blade like this/ (long top link)digs whereas blade like this\ (shortened top link) slides. It works the same with the rake teeth. With the top link adjusted out long, the blade wont come off the ground as much though.
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
UNUSED 7/10 in. Twisted Manila Rope (A50860)
UNUSED 7/10 in...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
