Anybody have a new holland 3930?
   / Anybody have a new holland 3930? #1
AlbertC
Perry, GA
New holland 3930
I have a 1999 new holland 3930. My tractor has a one cartridge fuel/ water separator. It does not look like the picture that came with my owners manual that shows two cartridge set up with a fuel filter and sediment separator.
I want to change the filter but am unsure about what to do, specifically whether or not I will have to bleed the system. I know that I need to shut off the fuel, remove old filter, fill new filter with fuel and re-install the new filter and then turn the shut off back on. But do I have to bleed the system anywhere or just try to start it back up.
Thanks for any help.
   / Anybody have a new holland 3930? #2
You'll probably have to bleed the pump. Sometimes you can get lucky and it'll start. There's a bolt on top of the pump you loosen until fuel comes out, and then it's usually good to go.
   / Anybody have a new holland 3930? #3
This, but I have never gotten lucky. Always had to bleed.
   / Anybody have a new holland 3930? #4
Probably an aftermarket filter, but should have a bleed screw on top of the filter head. Do the procedure you described including bleeding the filter, then start the tractor with at least half throttle.
8 sets of Jumper Cables (New/Unused) (A59225)
8 sets of Jumper...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
John Deere Gator (A53317)
John Deere Gator...
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
