Rear Finish Mower changing blades/working under Swisher 66 trail mower
   / changing blades/working under Swisher 66 trail mower #1
AppleMan
Member
Northern IL/Southcentral WI
JD 2305, JD 850, 1951 Farmall
I'm trying to figure out a better way to clean out the grass from underneath my Swisher 66" trail mower and find a way to change the blades. I've been jacking it up and using cinderblocks but that isn't the safest. It's too heavy for me to push onto it's side and the front wheels rotate/twist making it hard to chock all wheels. If anyone has a good way to work underneath these, especially how to chock the blades from turning so I can get them out, any advice is appreciated.
Thanks!
   / changing blades/working under Swisher 66 trail mower #2
Do you have a tractor with a loader? An air wrench will cure the other problem.
   / changing blades/working under Swisher 66 trail mower #3
You can pick up a cherry picker pretty cheap at Harbor Freight.
I've got the 57" Trail Cutter and have been thinking about this myself. Pretty good cutter but I hate the way you have to adjust the height. These should be pop-out pins - and I plan to find something like that to replace the bolts.
1 Ton Capacity Foldable Shop Crane
   / changing blades/working under Swisher 66 trail mower #4
Before I got my tractor I would winch it up to the garage rafters until vertical. I drain the oil and remove the gas tank first. I'm getting pretty good at this procedure as I change the shaft bearings and blades every spring. Of all the machinery I own this one requires the most maintenance. I took them at there word when they said rough cut.
   / changing blades/working under Swisher 66 trail mower #5
Why do you change the shaft bearings every spring?
   / changing blades/working under Swisher 66 trail mower #6
If I don't, I get to about mid June before I have a major failure and haul it back to town to do them along with the spacers and washers and maybe a shaft. The bearings only cost $6 each and I can get them changed in a little over an hour.
Admittedly I do abuse this thing a bit. As time goes on though most of the really tough cutting is getting to be less each year.
I do, but it's not great. They say it can handle 750b, but I think it's much less after using it 10 years. The mower weighs 560lbs. I completely didn't think about air wrenches, thanks much!
Thanks I'll check them out.
   / changing blades/working under Swisher 66 trail mower #9
I have mowers with thousands of hours on them with all factory spindle bearings. They also get abused. The only spindle bearing I have ever had fail had 800 hours on it.
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55314)
2019 New Holland...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
Enmark Z Spray (A53316)
Enmark Z Spray...
