buickanddeere
Super Member
And this pertains to what? You can't get the 5.3 in a 3/4 ton...
Rare is the application that actually hauls over 10,000lbs and needs a class A license. The GM HD half tons are rated for 9900lbs .
Actually the GM half tons are rated 12,000 pounds max towing with the 6.2L and 10,800 for the 5.3LRare is the application that actually hauls over 10,000lbs and needs a class A license. The GM HD half tons are rated for 9900lbs .
Just to make sure anyone 37 years old or younger contemplating purchasing a new truck won't be saying coulda, woulda, shoulda in 30 years... $60,000 earning 7% compounded annually for 30 years will give you a tad over $450,000 at retirement age. Hope you get a half million dollars worth of enjoyment out of that truck.![]()
That's a good real life way to look at it. Also makes me happy with my decision to wait a few more years to trade in my 07.
What mileage do you get if you don't mind me asking. $120K for a real truck and $84K for a pickup. Amazing.
$84K for a pickup? What left field did that come out of? Not sure I follow that one. I did pay $120 for the semi tractor new, but the way I did it, I actually saved $40K over the normal price for a similarly spec'd new truck. How? By ordering a new truck minus the engine and transmission. I then dropped in a factory rebuilt engine and factory rebuilt trans. Doing so, I got to avoid the 14.5% Federal Excise Tax on new equipment and got to avoid all the emissions junk being placed on new trucks nowadays. EPA ties the emissions to the year the motor was built, not the vehicle. If it comes from the factory with a motor, you are stuck with that year. If it comes without a motor, you can drop in whatever you want and it only has to comply with emission from the year the motor was initially made. Sneaky eh? And that setup is averaging right around 7.83 mpg over the last 405,000 miles. Not bad for a commercial semi truck, 53' trailer, with gross weights up to 80K lb. A typical new truck spec'd the same as mine except with new motor and trans and all the emissions stuff and the federal excise tax would be near $160K.
Duwop, Nice pickup that sounds like pretty good mileage for those gears, Can you burn ethanol in the 6.2L engines?
