185 hydro having issues moving forward and reverse
/ 185 hydro having issues moving forward and reverse #1
4mustangs
auburntown, tn
JD185 hydro lawn tractor
I have an older JD 185 Hydro, serial #M001858511130-46. The other day while I was mowing I smelled a light hot rubber smell. The mower than stopped moving forward with any power and the same thing happens in reverse. As I acquired this tractor used a couple of years ago I have no owners/operators manual to help me out here. I don't know what year it is but I am guessing the 46 at the end of the serial # means it is a 46" mowing deck?
It also has a Kawasaki engine if that helps narrow down the age.
I have another minor issue that has developed. After mowing for a while when the engine is warmed up I pull it all the way down to idle and let it unwind for a few seconds it will backfire after shutting ignition off.
/ 185 hydro having issues moving forward and reverse #2
The parts book is free on the JD web site. In order to reduce the retail price and obtain sales from people who see the lowest price as the primary criteria. JD installed the cheap lightweight tuff torq K46 transaxle. There are upgrade kits to the K66 but they cost more than what the tractor is worth.
The lowest end JD lawn tractor that does have a beefy K58 transmission is the X310 .
Call the nice folks at 1-800-522-7448 for the operator's and service manual on CD or hard copy.
/ 185 hydro having issues moving forward and reverse #3
I agree with B&D on getting a service manual if you plan to work on it yourself.
The 185 does not have a k46 transmission though, it either has an Eaton or more likely a Sunstrand transmission.
/ 185 hydro having issues moving forward and reverse #4
:welcome: to TBN
The carb may have a fuel shutoff solenoid that is not working. You will see it in jdparts.com if you go there (free registration).
The smell may be the belt driving the tranny... and needs replacement or new sheave/pulley(s). Those too you will see in the parts schematics at jdparts.com
So how do I know which transmission my mower has?
/ 185 hydro having issues moving forward and reverse #6
If it were me I would find the identification numbers on the transmission, look at the diagrams and listings on jd parts, enter your model 185 and look towards the bottom of the list for the 185 lawn tractor. Once you get to the listings you can find all the parts on your tractor. Write down your serial number and any numbers you find on the transmission case and or tags. There are a couple of serial number breakdowns using these transmissions.
/ 185 hydro having issues moving forward and reverse #7
Could be this lawn tractor ? TractorData.com John Deere 185 tractor information
I stand corrected.Transmission:
Transmission: Sundstrand
Type: hydrostatic
Gears: infinite forward and reverse
Oil capacity: 0.75 qts [0.7 L]
Part the 185 out on ebay and use the proceeds as a down payment on something that uses fire bolts to bold the rear wheels on.
/ 185 hydro having issues moving forward and reverse #8
Type: hydrostatic
I had a Husqvarna LGT 2554 with 5 bolt rear wheels that had a K-46 in it. It went bad on me after I put on 118 hours, which brought it up to 136 hours total. (I was hauling wet birch firewood up a big hill too many times. Mowed one summer, as I recall, with it and hauled firewood one summer and it was done!
Never did anything with it I wouldn't have done with my 12 or 13 year old Craftsman lawn tractor which has a 21 1/2 hp briggs with manual tranny.
Art
Art
Thanks for all the info. I'm not ready to give up on this mower yet and part it out. Even if I have to rebuild/replace the tranny I feel like it will be worth the cost as there are a lot more years left in this mower.
Having said that is there a rebuild kit available for this tranny that anyone knows of and can reccomend?
Thanks again,
/ 185 hydro having issues moving forward and reverse #10
Art
I have never seen a k46 with five bolt rims. Just a square key way and a circle clip. The K66 is the lightest Tuff Torq with a five bolt rim.
/ 185 hydro having issues moving forward and reverse #11
Thanks again,
Maybe eBay ?
/ 185 hydro having issues moving forward and reverse #12
I was trying to put in a picture of this page but can't figure out how to do it. On this page it shows that my 09 Husqvarna LGT 2554 big box store "gardentractor" did indeed have the K-46. It also had five bolt wheels. I was really surprised when I figured that out. And not happy either.
Not trying to argue with anyone here.
Just hoping someone can learn from my disappointment. And that they can avoid the financial hit that comes with it. Husqvarna LGT 2554 (96045001500) - Husqvarna Lawn Tractor (2009-01) Drive Diagram and Parts List | PartsTree.com
I have since learned some models and brands actually have the tranny model listed in a sticker on the seat bottom!
Art
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A62129)
CATERPILLAR 631E...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2021 John Deere Z960M Zero Turn (A63116)
2021 John Deere...
