Suggestions for must haves for a new Tractor owner?
   / Suggestions for must haves for a new Tractor owner? #11
Seat time. Priceless. Actually my most used go-to tool is a ten foot length of 3/8 chain.....
Yep, what he said.
Even 5/16" - G43 is probably all you will need with a CK unless your really pullin' extraordinary heavy stuff with it. Get the dealer to weld you on some bucket grab hooks.
   / Suggestions for must haves for a new Tractor owner? #12
Yep, what he said.
Strength wise, 1/4" will likely hold all you can pull and then some, but I like to go bigger just for extra safety. I also go with gr. 70 because you can get more strength with a smaller chain. If you plan to trailer it, look at the requirement for tie-down and buy enough grade 70 in the strength you need to put 4 corner ties on the tractor. Most states require separate ties for attachments including the FEL, backhoe, and even the back hoe bucket might require separate tie off. I usually use nylon straps for the attachments but chains for the tractor.
My advice is unless you need a box blade immediately, forego getting a new one. Look for a used one and save about 50% of the cost. It seems almost everyone, myself included, buys a box blade. I haven't used mine in years although I did use it a bit to level my shop location prior building. I also bought a landscape rake that I thought would be useful for grading my interior road, and it does work, but I can back drag it with my B26 FEL in less time than it takes to hook up the rake so it has become a chicken perch and they seem to like it as a bathroom location. Same with my box blade. Lots of folks use them for grading gravel roads but since I have such short road, I don't need it for that.
I haven't used my disk harrow in a couple years now since I got my King Kutter II tiller. I use it instead of the disk for garden prep. I even used it on a pasture fire once to cut a fire brake at over 8 MPH and it did a great job.
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Extended Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
2010 Ford F-150 Pickup Truck (A55973)
2010 Ford F-150...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A56435)
2023 Kubota L3560...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
