Alien Invasion - I want my pond back !
/ Alien Invasion - I want my pond back ! #31
A vacuum pump?
Connect the outlet end of pipe to the air intake on your tractor. Start your engine. :laughing:
/ Alien Invasion - I want my pond back ! #37
Is this thread like one of those books where you choose what happens next? If you choose 'suck on the pipe', go to post #47. If you choose 'use a pump', go to post #43.
This is a rather enjoyable thread...I'm on the edge of my keyboard!
/ Alien Invasion - I want my pond back ! #38
Could you plug the end in the pond and fill the other end with a garden hose then remove the plug and hose at the same time? A vacuum pump would work. A shop vac couldn't pull the water high enough.
/ Alien Invasion - I want my pond back ! #39
That's a good idea, but I don't think you would have to plug the end in the pond. You would want to leave it open to let the water coming in from the hose force the air out. Then, remove the water hose and voila!
It's still fun to speculate what the OP did, even though this was done 6-8 years ago. :)
/ Alien Invasion - I want my pond back ! #40
All set to go, except for one bit of detail. How do you prime a siphon that's over 200 yards in length ?
Put a valve on each end. Lay the pipe on an incline and pump it full of water, letting all air escape. Close the valves. Put the ends in their respective places and open the valves.
I thot you had to be done by 2006.
New Holland 3930 (A60462)
New Holland 3930...
John Deere HX20 (A60462)
John Deere HX20...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
