Rotary Cutter Decision Time for Bush Hog / Rotary Cutter
   / Decision Time for Bush Hog / Rotary Cutter #11
With a 59 hp tractor, I wouldn't even bother with a 6'. I'd go either 7' or 8' at a minimum, or the batwind as someone mentioned above.
I have a BH 276, which is a 6', 1000lb bushhog. I wish had gone with a 7' for the +15 acres I have to mow.
   / Decision Time for Bush Hog / Rotary Cutter #12
We have quite a bit of land we mow, so we have a 10' in addition to the 6', but for 10 acres, I wouldn't spend the money on anything bigger than a 6'. I looked at a 7' and it's really bulky, I like the twin spindle 8', but the price bump just wouldn't be worth it to me anyway.
   / Decision Time for Bush Hog / Rotary Cutter #13
I have found over my years of a lot of mowing I am always doing more then the mower will do. That is why I went with the heavier gearbox.
   / Decision Time for Bush Hog / Rotary Cutter #14
I agree with going with an 8' twin spindle instead of a 7' single spindle. A medium duty 7' mower is really long and hangs way back there. I think an 8' twin spindle requires less HP than a 7' single spindle does. But I think the minimum for an 8' twin spindle is about $4,000, a lot of which is probably because of 3 gear boxes instead of 1.
   / Decision Time for Bush Hog / Rotary Cutter #15
Yeah, the twin spindles do get pricey, I about stroked out when we had to write a check for our Woods DS1260 a few years ago.
The reason I was going for a 6' mower was to be able to scoot around all the trees on the property. I am clearing all the smaller trees on the property now but plan on leaving a good amount of the larger trees. I would love to speed up the amount of time on the mower with a larger mower, but a 6 footer seems like the best fit. Can you get reasonable cut quality with these as opposed to getting a finish mower and wearing it out in a short order?
Thanks.
Steve
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
2014 CM TRAILER CARGO (A55745)
2014 CM TRAILER...
2003 Big Tex 10PI...
