Part fell off, where does it go?
/ Part fell off, where does it go? #1
dablack
Member
Rusk, TX
Kubota B2620
OK guys. I've got a B2620. I found this hose sitting right under my tractor. I don't know when it fell off. I always park my tractor here. I'm assuming it is a vent of some kind.
Any ideas?
/ Part fell off, where does it go? #2
Looks like it could be an overflow hose from the coolant reservoir.
/ Part fell off, where does it go? #3
That would be my first guess. If you don't have it figured out by then, I will take a look at mine when I get home in a few hours.
/ Part fell off, where does it go? #4
If not coolant, could be the diesel overflow coming off the fill cap area.
That's my guess!!!
Thanks guys. I won't be home until tonight. If it isn't pouring, then I will check the guesses and see what it is. I was on my way inside when I found it so I didn't have time to even look under the hood.
/ Part fell off, where does it go? #7
Looks just like my crank vent hose. My coolant hose is clear.
/ Part fell off, where does it go? #8
One other idea, some tractors have a front axle vent tube that will come from near the center of the axle and go up horizontal to the engine area. The idea is to vent the axle but be high enough that water wont get in if you submerge the axle in a lower water crossing or something.
/ Part fell off, where does it go? #9
Do you have a dog? Maybe he drug it over from the neighbor's house and is playing a dirty trick on you.
/ Part fell off, where does it go? #11
Is there any diesel left in your tank? :laughing:
Sorry, I couldn't resist.
I guess it could be the return fuel line... but should still be a heck of a mess!
/ Part fell off, where does it go? #12
Mine is old ,but it looks like the tube off the radiator neck
/ Part fell off, where does it go? #14
Spare parts bin.
/ Part fell off, where does it go? #15
I used to have a 2620 and can't recall ever seeing anything like that. I think it might be the fuel overflow hose to direct overflow from the top of the tank area to the ground. Good luck!
OK guys. Between storms, I only had time to run out and pop the hood real quick. It is not the coolant overflow or the crankcase vent.
I'm going to check the diesel overflow line next chance I get......if it ever stops raining.
/ Part fell off, where does it go? #17
OK check the front dif. vent there's a tube just like that on mine and it's the same dif. as Kubota has.
/ Part fell off, where does it go? #19
Shoot, my B2620 drops parts all the time. I just toss em in a pile until it shuts down.
My bet is diesel overflow. Looks just like the one off my b7500
If it is the diesel overflow line, I'm not sure how I would know. I popped the cap on the fuel tank and can't see anything there. How do you even get to that line to see if it is there or not?
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
