Using a dump tandem axle trailer for hauling tractor?
/ Using a dump tandem axle trailer for hauling tractor? #11
Not actually. The backhoe will drag the ground on the ground-to-ramp transition. The beds on all the dump trailers I have seen are hinged at the very rearmost part of the bed. When you raise the bed, the ramp-to bed angle changes; but without lowering the back edge of the bed, the ground-to-ramp transition stays at the same angle... Tilting the bed would only help if you were high-centering between the front and rear axles on the transition from ramp-to-bed. The way to reduce the ground-to-ramp transition angle would be to back the trailer to a slight grade and have the tail-end of the ramps elevated onto the grade, or to use longer ramps. That being said, a backhoe can have the bucket raised into the air for clearance during loading and lowered to the transport position once on the trailer, or you can back it on allowing the backhoe to go between the ramps until the back tires start up the ramps.
Most BH dragging situations I have seen is not the bucket but the frame and main pivot are. They seem to hang very low on the CUT tractors.
Chris
/ Using a dump tandem axle trailer for hauling tractor? #12
If you're going to haul the tractor a lot, it will likely be a pain, but for the occasional use, I think it's a good idea...just bought a dump trailer a couple of weeks ago. There are now low profile dump trailers with 24-25" loading heights, which helps with the loading ramp angle. The downside is they do give up some ground clearance on the axles. Here's my new rig (14K, 16') hauling brush:
Good info gents, thank you. Due to my limited parking space and my intense desire to NOT look like the Clampits, I was leaning toward a dual purpose trailer. I'm also thinking of starting up a LLC and do tractor/handy man jobs on the side to supplement my income. Currently, I'm an unemployed engineer who is seeking employment and having some money coming in from odds and ends jobs would take the sting out this cycle.
As stated already, a 12' trailer would be a tad tight but I'll rent it for four hours one day and see how it goes just for S&G. I can always borrow my buddies giant 8x20 trailer but it's a PITA to park it at my place. I found that if I backed up the tractor then the BH does have an easier time loading/unloading. Also, the weight distribution seems to be better when I back in vs pulling in fwd.
I'm happy to hear about the low profile dump trailers, that's good to know. However, when I have to go to the forest to get fire wood, having a high clearance trailer is a must out here. The ruts get so deep, it's easy to drag the belly of a loaded trailer. Just about every fire wood outing becomes a 4x4 excursion with tow straps, winching, lockers and all that fun stuff it seems.
Pardon this newbie question but if I were to use a dump trailer for transport with high side walls, would I still be using tie down straps/chains? I've seen the pros back in their BH and then curl their bucket tip on the tongue rail to prevent movements during transport.
Keep the ideas coming!
/ Using a dump tandem axle trailer for hauling tractor? #14
Chris
Still, if they are dragging the ground on the ground-to-ramp transition, that angle is changed none by tilting the bed unless the bed hinge is forward of the rear of the bed. I've only seen dump trailers with their hinge points at the rearmost part of the bed, which doesn't change the angle at the ground or help the dragging on the ground as was suggested.
I'd like to see a dump trailer that was hinged farther forward and the rearmost part of the bed would lower some as the bed was tilted up. I'd drive to the other side of the country to buy me one of them.
/ Using a dump tandem axle trailer for hauling tractor? #15
Chances are you'll need to jump in with both feet and do the odd jobs full time to cover the insurance costs that come with operating equipment in other places.
I'm pretty sure all states require loads to be secured in the trailer. I personally wouldn't want to go down the freeway without everything being held securely and also a backup retention device also securing it. Parking brake, in lowest gear available, buckets or implements down, chain on each; the tractor, the buckets, and the implements.
/ Using a dump tandem axle trailer for hauling tractor? #16
Still, if they are dragging the ground on the ground-to-ramp transition, that angle is changed none by tilting the bed unless the bed hinge is forward of the rear of the bed. I've only seen dump trailers with their hinge points at the rearmost part of the bed, which doesn't change the angle at the ground or help the dragging as was suggested. I'd like to see a dump trailer that was hinged farther forward and the rearmost part of the bed would lower some as the bed was tilted up. I'd drive to the other side of the country to buy me one of them.
You would only have to go half way across the country to find one http://www.midsotamfg.com/pages/DumpTrailers
I have used the forward hinged Midsota dump trailers quite a bit and they work very well. The forward hinge also makes the lift system work more effectively when you are trying to get a heavy load tipped up.
/ Using a dump tandem axle trailer for hauling tractor? #17
Very nice! They do exist (but are apparently somewhat rare). With so many dumps being easily overloaded on the front causing trouble lifting, I always thought that moving the hinge forward some would be a great idea to overcome that sort of issue and was disappointed when my searching yielded nothing.
I've honestly looked at gobs of manufacturers and have never seen one that hinged anyplace other than right at the back of the bed, and many of them with the geometry they're built with, actually raise the tail edge of the bed a couple inches as it tilts.
Good find HHR!
/ Using a dump tandem axle trailer for hauling tractor? #18
I haven't put a ruler to it, but it seems like when I raise the bed on mine, the rearmost part of the bed is slightly lower. I'll try to measure it to see for sure. Even if it does lower, it's not going to be a big difference. I really wanted a low profile trailer, but losing the ground clearance was going to be too much of a risk. One of my barn doors is slightly elevated, so I plan to use that if I have trouble loading something that needs a shallower approach angle.
/ Using a dump tandem axle trailer for hauling tractor? #19
I haul my M59 TLB in a 16' low profile dump trailer. It is easy to load, I can easily reach over the sides to chain it down, and overall I really like it. I have a couple gooseneck equipment trailers as well but I see no need to use them as the dump trailer works just fine and is not any kind of hassle.
/ Using a dump tandem axle trailer for hauling tractor? #20
Bdog that looks like a nice setup. I should have looked for something with lower sides like that. The sides on my trailer are taller and make reaching over the side impossible.
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
Auger Drill Bit Skid Steer Attachment (A59228)
Auger Drill Bit...
2016 Ford F-150 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
10in Digging Tooth Bucket Excavator Attachment (A60352)
10in Digging Tooth...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61307)
Midwestern...
