Grille Guard
/ Grille Guard #1
PHPaul
Downeast Maine
Kubota B2650 with cab, Pasquali 986
The "grille guard" that came with the loader on my new B2650 is a joke. It might help if something fell straight down off the loader, but not much, and any sticks/twigs/brush would go through it at will. I learned my lesson on that with my old JD, and it's an expensive lesson to learn.
So I while I was in town this morning I bought a couple of sticks of 1/4" rod and a small sheet of expanded metal.
The rod was heated and bent to fit inside the framework of the guard and then the expanded metal was trimmed to fit the outline of the rod and tacked to the rod.
Then the rod-framed expanded metal was welded inside the guard frame.
All the fab is done, now just need to prime, mask and re-paint.
/ Grille Guard #2
Looks great. Maybe send it to Kubota's engineers and say "see how easy it is to get it right"
/ Grille Guard #3
Looks good. I just welded the expanded metal directly to the stock grill guard.
/ Grille Guard
Aaron, That's what I did on the JD but the 'bota has so many angles and curves it would have been a huge PITA to get it right. The recessed approach went pretty smoothly.
/ Grille Guard
That thought occurred to me. The original design is pretty useless.
/ Grille Guard #6
That though occurred to me. The original design is pretty useless.
Nice guard Paul.
Don't bother with the Kubota engineer thing. I once modified the FEL latch pins with the addition of a spring which holds the latch pin in place all the time. I sent an email to Kubota with pictures explaining the modification. I also explained that I wasn't looking for anything in return. Just thought they might want to adapt something similar. I got an immediate response. It was a stern warning that any modification to the FEL frame and/or it's latch mechanism would void my warranty if problems occurred........
/ Grille Guard
Not surprised. Stinkin' liability lawyers...
/ Grille Guard #8
Nice guard Paul.
View attachment 424408 View attachment 424409
Reminds me of the old saying --- "No good deed goes unpunished"!
MoKelly
/ Grille Guard #11
I need to build something similar. I have never personally learned that lesson, but several family members have.
/ Grille Guard #12
I like that. I have a B2630 with out the Guard, but I have a press brake and I just need to lay out a guard and start bending..
/ Grille Guard
Post some pics when you get her all painted up Paul!!!
Note to self: Krylon's Farm Implement Kubota Orange....ain't. Maybe for the older 'botas but the B2650 is noticeably more red.
Hafta do for now tho, I got stuff to do. I'll pick up a can of the Rustoleum Lobster Red and see it that comes closer as advertised.
/ Grille Guard #14
Looks great Paul. Should give you some comfort in the brush. :)
/ Grille Guard #16
Rained yesterday so I made an effort to make a bush guard out of what was available. Not nearly as efficient as the ones posted but I'll incorporate expanded metal when I get some.
/ Grille Guard
Looks good! 1/4" round stock?
Home Depot has 3/4" expanded metal in 2x2 sheets, that's what I used.
Normally, I wouldn't buy steel from a hardware store as the per pound price is just insane. However, the nearest real steel supplier is a 100 mile round trip and I don't currently need anything else, so the extra "boutique" charge for the little piece was worth it.
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
2020 CATERPILLAR 306CR EXCAVATOR (A65053)
2020 CATERPILLAR...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
