TC40A Gear drive and the Rabbit/tortoise switch on the joystick
   / TC40A Gear drive and the Rabbit/tortoise switch on the joystick #1
newholly
new jersey
green
I have a TC40A Gear drive with a 250tl, is the Rabbit/tortoise switch on the joystick non operational for gear tractors? is it only for HST transmissions? It doesnt appear to do anything and I was hoping to use this for a 3rd function switch for a grappler. Thanks
Well I confirmed it does nothing on a gear tractor. It wasn't hooked up to anything.
   / TC40A Gear drive and the Rabbit/tortoise switch on the joystick #3
What is this switch supposed to do? I have a tortoise rabbit switch just below the seat on my 2003 NH TC30. You turn it left or right - a couple of turns either way. What is it supposed to do? I have a gear tractor.
Just below it I have a heel lever to lock up the rear axle that I never use. I also have a foot fuel throttle along with the hand one. I don't use either. (did use the heel lever once when I got hung up in snow, one tire free spinning)
This rabbit tortoise switch is just another that I never used.
I was looking at it today and got to wondering- looking around the internet tonight there was something about using it to relieve hydraulic pressure by opening or closing it. Loader related? Transmission related?
   / TC40A Gear drive and the Rabbit/tortoise switch on the joystick #4
That knob is to set the lift speed of your 3PH... once you've set it at the desired rate it's pretty much 'out of sight, out of mind'.
   / TC40A Gear drive and the Rabbit/tortoise switch on the joystick #5
-good to know, thanks
   / TC40A Gear drive and the Rabbit/tortoise switch on the joystick #7
Isn't the knob under the seat to control rate of 3ph drop only? Does not affect raising speed.
Jim
   / TC40A Gear drive and the Rabbit/tortoise switch on the joystick #9
Jim
Yeah, you're right (RickB too). The revs to operate the hydraulics + the handle determines the raise speed (at least on my rig).
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Hose Reel (A55787)
Hose Reel (A55787)
White Metal Roof Panels (A55758)
White Metal Roof...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
